 2019 m. sausio 17 d. Projektas | Reklama | Žinokite | Klausimai | Prisidėkite | Atsiliepimai | Kontaktai
Dabar yra 2019 01 17, 11:37. Visos datos yra GMT + 2 valandos.
 Forumas » Ieško, perka daiktus » Holo daviklio MLX90215 programavimas
PranešimasParašytas: 2019 01 09, 11:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
saulux2005
Sveiki!
Gal kam teko tureti reikalu su programuojamu holo davikliu MLX90215 ar panasiu?
Porai vnt. pramusti isejimai. Nusipirkti galima, bet glumina ar nereiks kartais jo uzprogramuoti.
Ar esate kas nors susidures su skaitymu/rasymu tokio daikto?
Aciu!
 jutiklis
PranešimasParašytas: 2019 01 09, 15:49 Pranešti apie taisyklių pažeidimą Atsakyti su citata
satsek13
4 How does it work?
The MLX90215 programming is done through the output pin, by changing supply voltage levels. Please
note that the VDD is raised to approximately 13V and 18V during programming. Any connected components
must also tolerate this voltage excursion. When the supply voltage is at 4.5V to 5.5V, the output behaves
normally. If the supply voltage is raised to 13V, the output then behaves as an input, or LOAD mode,
allowing the 37-bit word to be clocked in. All data is loaded through a single line, with no dedicated clock
signal. Clock and data are integrated into one signal which is initiated with the beginning of the LOAD
sequence, then clocked with the positive edge of each bit. Variables are changed with the PC software and
loaded into the temporary register of the device (RAM) via the timings of the programmer’s microcontroller.
Data can be loaded as many times as desired while in LOAD mode. Once a word is loaded, results are
checked by observing the output voltage. This can be done with an external Voltmeter attached directly to pin
4 of the device, or with the internal ADC of the programmer. Once the desired program is loaded, the
word can be “Zapped” permanently into ROM. This is done when the supply voltage rises above 18V,
or ZAP mode, creating enough current to “Zap” 31 zener diodes which correspond to the temporary
register. The ZAP function is a one-time function and cannot be erased. The above description is only for reference. The
voltage levels and data transfer rates are completely controlled by the ASIC programmer. For more information on the
programmer hardware, contact Melexis and request a datasheet for the SDAP programmer.
Programming The Quiescent Offset Voltage (VOQ)10 bits, 1024 steps of resolution, are allotted to adjust the
Quiescent Offset Voltage (VOQ). By utilizing the HALFVDD function, the VOQ can be set to one of two ranges. With the
HALFVDD function disabled, the VOQ can be programmed within a range of 10% to 90% VDD with about 5mV per step
resolution. With the HALFVDD function enabled, the device may be programmed within a 2V to 3V window with less
than 1mV per step resolution.
Programming the Sensitivity (Gain)
The sensitivity is programmed with a ROUGHGAIN and a FINEGAIN adjustment. The ROUGHGAIN is
adjusted by utilizing three bits, or 8 increments. The FINEGAIN is programmed with 10 bits or 1024
increments. The sensitivity can be programmed within a range of 5mV/mT to 140mV/mT. Another 1-bit function
allows the direction of the sensitivity to be reversed. The INVERTSLOPE function, when activated, will
cause the Voltage output of the MLX90215 to decrease in the presence of a South magnetic field, and to
increase in the presence of a North magnetic field. Table 2 expresses examples of sensitivity resulting from
programming ROUGH GAIN and FINE GAIN codes, with the INVERT SLOPE function turned off.
Note: Tables 1 and 2 are examples how various codes affect the device. Output voltage will vary slightly from device to device. Use these tables
PranešimasParašytas: 2019 01 09, 16:29 Pranešti apie taisyklių pažeidimą Atsakyti su citata
saulux2005
6 Melexis Programmer
Melexis offers a programmer (PTC-01) for programming the MLX90215. The PTC-01 comes
complete with windows based software that makes programming the MLX90215 simple. The programmer
communicates with a PC via a RS232 serial interface. The programmer and software allows users to load
settings in the MLX90215, take measurements, calibrate sensors, and program the MLX90215. For
more information the PTC-01 goto www.melexis.com, or contact Melexis.
PranešimasParašytas: 2019 01 09, 17:46 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sopkls
Datašytus perskaityti daugelis moka, tu geriau pasakyk kaip tą PTC-01 pačiam pasigaminti.
 pr.
PranešimasParašytas: 2019 01 10, 07:47 Pranešti apie taisyklių pažeidimą Atsakyti su citata
satsek13
Parašiau dėl apsišvietimo kas reikalinga būtų. Pasidaryt pačiam nepavyks ir neapsimokėtų - optimistiškai. Tiesiog įrangos gamintoją užprašyti reikia . kad patiektų jutiklį - pigiausias ir įprastas metodas.
TMS ELECTRONICS
TMS ELECTRONICS
www.rslietuva.com – nemokamas elektronikos komponentų pristatymas
Lietuvos mokinių neformaliojo švietimo centras
„EParašas“ – elektroninio parašo mokymo sistema
CRM sistema – „Hanna CRM“
www.rrt.lt – Lietuvos Respublikos ryšių reguliavimo tarnyba
FS 19 Tractor mods
Farming Simulator 19 Mods, FS 19 Maps, How to install
ATS mods
ATS trailer mods, ATS truck mods, ATS map mods
FS 19 Tractors
Farming Simulator 19 Mods, FS 19 Maps, FS 19 Trucks
FS19 Maps, FS19 Trucks
Farming Simulator 2019 Mods, FS19 Tractors
FS 17 maps, FS 17 truck
FS 17 Trailers, Farming Simulator 2017 Mods
FS 2017 Trailers, FS 17 Maps, FS 17 Tractors
FS 19 Tractors
Farming Simulator 19 Mods, FS19 Combine, FS19 Maps
FS19 Combines
Farming Simulator 19 Mods, FS19 Trucks, FS 19 Mods
Periodontologija
Endodontija mikroskopu, implantacija, protezavimas
Mobilieji telefonai
Mobilieji telefonai internetu, telefonų dėklai, telefonų priedai
Farming Simulator 2017 Mods, FS 17 Mods
ls2017.com
„TV programa“ – tiksli
televizijos programa
www.tvprograma.lt
www.lmnsc.lt
Lietuvių kalba informacinėse technologijose
www.likit.lt
Svarstyklės, matuokliai, laboratorinė įranga
www.moris.lt
Farming Simulator 2019 Mods, LS19 Mods, FS19 Mods
fs19.net
Ets2 mods, ats mods, fs19 mods
Farming Simulator 2019 Mods, FS 19 Maps, FS 19 Mods
www.fs2017mod.com
LTV.LT – geriausių lietuviškų tinklalapių katalogas
FS 2019 Mods, FS 2017 Mods, FS 2015 Mods
www.farming2015mods.com
Mokslo populiarinimo projektas „Mokslas verslui ir visuomenei“
