Dabar yra 2026 04 27, 12:06. Visos datos yra GMT + 2 valandos.
Forumas » Programinė įranga » beda su dmx ir freestyler
Re: beda su dmx ir freestyler |
Parašytas: 2018 08 15, 14:40 |
tavo nuorodoje..
The signed driver for Windows XP, Vista and Windows 7 (32-bit). Besides, on Unix-based operating systems, the LibUSB is integrated directly into the kernel.
Uncompress the file wherever you want and then plugin the hardware.
The operating system will search for a driver.
Select the correct directory (of you uncompression),
After several seconds the driver should be installed
ATTENTION: And then the file uDMX.dll has to be MANUALLY copied to the directory <Windows>\System32\ in order to finish the installation.
After uDMX.dll has been copied to the directory of <windows>\System32\, for example C:\WINDOWS\system32, the driver installation is finished."
This works for example with:
DMX-Control
Freestyler
Magic Q
Abuelites"
NOTE: It is not compatible with the all dmx Software.
Until now, we know that it can be compatible with the software FreeStyler DMXControl PC-Dimmer, Q Light
Controller Vixen Abuelites, MagicQ. If you use other software, please consult us before purchase.
The signed driver for Windows XP, Vista and Windows 7. Besides, on Unix-based operating systems, the LibUSB is integrated directly into the kernel.
programų pavadinimai... . Pagal nuorodą - bent jau 32 bit win reiktu pabandyti, kad ir tuos pačius win 10,
blog-as kaip tai padaryti su win 10 64 bit http://blog.ricohansen.dk/Lists/Posts/Post.aspx?ID=45
Nepadės... ir paieška googlej su užklausa .. dmx512 adapter WIN 10 64bit driver |
