 2026 m. gegužės 2 d. Projektas | Reklama | Žinokite | Klausimai | Prisidėkite | Atsiliepimai | Kontaktai
Dabar yra 2026 05 02, 16:18. Visos datos yra GMT + 2 valandos.
 Forumas » Autoelektronika » A6 C6 kodingas
 A6 C6 kodingas
PranešimasParašytas: 2018 04 04, 09:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
marxass
sveiki, reikia pagalbos sukoduot variklini ecu..perrasytas softas del perdarymo is automato.dabar keikiasi kodingas kaip suprantu del Auto Dist. Reg.kadangi donoro softe nebuvo..gal kas galite padet?
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 016 GB HW: 03G 906 016 GB
Component: R4 2,0L EDC G200SG 9663
Revision: --H02--- Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 69D39A9040E0040CAF-803C
1 Fault Found:
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - MIL ON
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 758 00200
VCID: 65CB96A0ACF8206C8B-8030
No fault code found.
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500809142
Coding: 0000129
Shop #: WSC 02780 202 96285
VCID: 63CF88B8A2CC5E5C65-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 A HW: 4E0 035 729
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 350FN077802571
Coding: 0001010
Shop #: WSC 02335 758 00200
VCID: 2143C2B0F8500C4C37-8074
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000793653
Subsystem 3 - Serial number: 0125.06.070000000100011774ÿ
Subsystem 4 - Serial number: 011774ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000412309
Coding: 0000276
VCID: 1C3DF344DF3221A4E4-8048
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
VCID: 316332F0A8B0BCCCA7-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046005 Serial number: AUZ5ZBG3421380
Shop #: WSC 00000 000 00000
VCID: 1835EF542B0A4D84C0-804C
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH01 0020
Revision: -------- Serial number: 00000000000000
Coding: 0061168
VCID: 234FC8B8E24C1E5C25-8076
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
01319 - Control Module for Distance Control (J428)
005 - No or Incorrect Basic Setting / Adaptation
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0SGX6+
Coding: 0013362
VCID: 2953DA908060C40C6F-807C
Subsystem 1 - Serial number: 6332CSME1A006077Z
Subsystem 2 - Serial number: 6342CSME1C284102Z
Subsystem 3 - Serial number: 6352QSME304617435
Subsystem 4 - Serial number: 6362QSME331724132
Subsystem 5 - Serial number: 63734SME30112D4B-
Subsystem 6 - Serial number: 63834SME2F4C52010
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90054071570346
Coding: 0002052
Shop #: WSC 02323 758 00200
VCID: 2757DCA89674F27C79-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 932 D
Component: KOMBIINSTR. M73 H21 0220
Revision: 00600000 Serial number: 64A50L567
Coding: 3460108
Shop #: WSC 15113 002 104857
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 E
Component: Gateway H11 0070
Revision: 11 Serial number: 1200906B14804C
Coding: EEEE53C41B3104
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H49 1060
Revision: 00000000 Serial number: 364F$077692296
Shop #: WSC 28258 001 1048576
VCID: 3B7F10D87AFC469C0D-806E
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
02927 - DVD Read Error
000 - - - Intermittent
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number:  †
Coding: 0003594
Shop #: WSC 02327 758 00200
VCID: 2C5D23848F92D12494-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01050743410000
Coding: 0000753
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
2 Faults Found:
00526 - Brake Light Switch (F)
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 K HW: 4F0 035 223 L
Component: Amp.-ASK-RD H07 0250
Revision: 09S00000
Coding: 020001
Shop #: WSC 02399 823 56573
VCID: 2649D1AC517EEB7442-8072
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000450673
Coding: 0001104
VCID: 5EB9B94C89AE73B44A-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: `„
Coding: 0003594
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000111
Shop #: WSC 02145 758 00200
VCID: 2045C7B4F35A054438-8074
1 Fault Found:
00650 - Clutch Pedal Switch (F36)
009 - Open or Short to Ground
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394FX077783322
Coding: 0000001
VCID: 2E59298CB98EA334BA-807A
2 Faults Found:
00532 - Supply Voltage B+
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000093449
Shop #: WSC 02780 202 59949
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 0706213440
Coding: 344630393135313035442056413030373036323133343430
Shop #: WSC 00000 384 00290
1 Fault Found:
02272 - Quiescent Current Stage 1
000 - -
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0003074
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0003074
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230717600669
Coding: 0000016
Shop #: WSC 12345 123 12345
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H16 0950
Revision: 00000000 Serial number: 00000007682791
Coding: 0010990
VCID: 2A51259C8566CF1466-807E
End-------------------------(Elapsed Time: 02:36)--------------------------
