Forumas » Mikrovaldikliai » VW/AUDI CD cheingerio emuletorius
VW/AUDI CD cheingerio emuletorius |
Parašytas: 2017 06 19, 13:54 |
Sveiki sugalvojau pasidaryti aux ant orginalios mages tam reikia emuliuoti cd
emuletoriaus programa turiu man reikia kad spaudant myktukus ant radijos, suveiktu isejimai ant arduino gal kas galetu pagelbeti komandu sarasa turiu |
Parašytas: 2017 06 21, 16:40 |
| Sawas rašo: |
| Gal kas galetu padeti programavime? |
kodo uz tave nerasysiu, iskilusius klausimus atsakysiu. jei tinka parasyk i skype |
_________________ Skype: dmb-220 |
Parašytas: 2017 06 29, 13:48 |
Gal kas zinote kaip arduino, SPI komandije sukonfiguruoti duomenu nuskaityma per 12 pina?
dabar siunciama informacija atvaizduoju lcd bet reikia sukonfiguruoti gaunama informacija ir pradiziai isvesti i lcd
Cia programa:
// Tested with Arduino Nano v3 Atmega328p
// Head unit tested: Skoda Symphony CD
// Connect pin 11 with DataIn
// pin 13 with Clock
// pin 12 with DataOut
// Gnd to Gnd
// DataIn (13) - Arduino 11
// Clock (15) - Arduino 13
// DataOut (14) -Arduino 12
// CDC Pilot Line (17) - Arduino VCC
#include <SPI.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(A5,A4,A3,A2,A1,A0);
void send_package(uint8_t c0, uint8_t c1, uint8_t c2, uint8_t c3, uint8_t c4, uint8_t c5, uint8_t c6, uint8_t c7);
void setup() {
// put your setup code here, to run once:
lcd.begin(16, 2);
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1);
SPI.setClockDivider(SPI_CLOCK_DIV128); //62.5kHz@8Mhz 125kHz@16MHz
send_package(0x34,0xBE,0xFE,0xFF,0xFF,0xFF,0xFA,0x3C); //load disc
delay(1000);
send_package(0x74,0xBE,0xFE,0xFF,0xFF,0xFF,0x8F,0x7C); //idle
delay(100);
void loop() {// put your main code here, to run repeatedly:
delay(500);
SPI.transfer(0x34);
delayMicroseconds(750);
SPI.transfer(c1);
SPI.transfer(c2);
SPI.transfer(c3);
SPI.transfer(c4);
SPI.transfer(c5);
SPI.transfer(0xCF);
SPI.transfer(c7);
lcd.setCursor(0, 0);
lcd.print(c0,HEX);
lcd.setCursor(4, 0);
lcd.print(c1,HEX);
lcd.setCursor(8, 0);
lcd.print(c2,HEX);
lcd.setCursor(12, 0);
lcd.print(c3,HEX);
lcd.setCursor(0, 1);
lcd.print(c4,HEX);
lcd.setCursor(4, 1);
lcd.print(c5,HEX);
lcd.setCursor(8, 1);
lcd.print(c6,HEX);
lcd.setCursor(12, 1);
lcd.print(c7,HEX);
