Dabar yra 2026 04 29, 11:50. Visos datos yra GMT + 2 valandos.
 Forumas » Elektronika žaliems » Dvd regijonai
 Dvd regijonai
PranešimasParašytas: 2006 08 03, 16:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Markus
samsung dvd cm350 regijonu atkodavimas
 Dvd regijonai
PranešimasParašytas: 2006 08 03, 18:55 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Bumbastik
pamegink suninkyti toki minkala Smile :
1. Power on your player as normal.
2. Press and hold both the Play and Forward buttons on the player.
3. After a short while the words "No Disc" should appear from the onscreen display. Release the Play and Forward buttons on the player.
4. First press the "Subtitle", then press the "Repeat" button on your remote control.
5. Using your remote control enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate:
- Region 1 use [ 2, 9, 3, 3, 4 ]
- Region 2 use [ 3, 8, 7, 6, 7 ]
- Region 3 use [ 5, 6, 7, 3, 2 ]
- Region 4 use [ 7, 6, 8, 8, 4 ]
- Region 5 use [ 5, 3, 8, 1, 4 ]
- Region 6 use [ 2, 4, 4, 6, 2 ]
6. A code should be displayed at the upper left of the screen showing the current Region setting of your unit.
7. Press the "9" button on your remote control for Region free, or "1" for Region 1. Press "2" for Region 2, and so on.
8. Press the Open button on your player, put a DVD movie. Don't press CLOSE!!!
9. Press the Standby button on your remote control.
10. Press Standby again, and wait untill u see the Samsung Digitall logo, press the PLAY button, and here you go, your movie should start now.
