Dabar yra 2026 06 03, 12:10. Visos datos yra GMT + 2 valandos.
 Forumas » Programavimas » windows 7 node list ar local hosts - ne į temą. Skubu
PranešimasParašytas: 2017 01 25, 09:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
a1girdas
atsiprašau, kad ne į temą. staigiai reikia, užkrito pavadinimas.
Yra IP adresų sąrašiukas, pagal kurį galima nukreipti į kompo folderį.
pavyzdžiui, http://172.31.50.121 bus nurodytas c:\Windows\temp\svetaine.htm
ir naršyklė (IE) kreipiantis tuo URL atidarys failą "svetaine.htm"
kaip tas sąrašiukas vadinasi, ir kur jis yra Windows 7 ir Windows 2008 server?
Local hosts, taip?
PranešimasParašytas: 2017 01 25, 10:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
http://helpdeskgeek.com/windows-7/windows-7-hosts-file/
arba
How to Get to and Edit the Hosts File
If you want to edit the hosts file, you first need to locate and open it - on Vista and newer with UAC enabled from an elevated process (with admin rights). The procedure is a little tedious. Here is how to do it with 64-bit Notepad:
Click on the Start button, type "notepad" and press CTRL+SHIFT+ENTER. Acknowledge the UAC dialog.
Type CTRL+O. Navigate to C:\Windows\System32\drivers\etc. Select "All Files" in the bottom right corner.
Now you see the hosts file. Select and open it. Make your changes and save it.
If you want to access hosts from a 32-bit process, use one of the following paths. Please note that in both cases the full path must be used. Navigating to "etc" from the root does not work (because System32 is redirected and Sysnative is not shown in directory listings).
%Windir%\System32\drivers\etc. This works because file system redirection is disabled for the "etc" directory and thus accessing the 64-bit System32 works from a 32-bit process.
%Windir%\Sysnative\drivers\etc. Sysnative is an alias that can only be used from 32-bit processes to access the 64-bit System32 directory.
PranešimasParašytas: 2017 01 26, 19:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
a1girdas
dėkui. Tos vat dalies su SystemNative nebuvau sugūglinęs. Vienok, ne taip paprasta šiuo atveju. įrašas hosts faile nepadėjo. nors, tiesą sakant, gal sintaksėje kokią klaidą įvėliau.
PranešimasParašytas: 2017 01 26, 20:34 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
i hosts faila rasai rašo:
172.31.50.121 hostname
jame paleidi www serveri ir i jo www aplanka imeti svetaine.html
tada kreipiantis http://hostname/svetaine.html atsivers tavo svetaine
PranešimasParašytas: 2017 01 27, 22:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
a1girdas
kuria prasme
jame paleidi
darbinis www servero folderis turi būti šitas? Ar IIS nustatymai tai ir yra www servero nustatymai, ar ... ?
PranešimasParašytas: 2017 01 28, 00:02 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
Kadangi nera zinoma kokia IIS serverio WWW direktorija, tai daleiskim adminas zino kur padeti konkreciai tavo failus
tada kreipies i ta serveri per ip
http://SERVERIO_IP/svetaine.html
ir turi atsidaryti tavo svetaine
jei tavo kompe hosts faile teisingai aprasytas statinis aliasas
SERVERIO_IP serverio_url
pvz:
172.31.50.121 alg1rdoSuperServeris
tai i ji gali kreiptis http://alg1rdoSuperServeris/svetaine.html
dar turek uomenyje, kad 172.16.0.0 .. 172.31.255.255 yra privatus potinklis, todel is isores jo niekas nematys
PranešimasParašytas: 2017 01 30, 21:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
a1girdas
dėkui didelinis, čia tiesiai į tašką kaip tik taip, kaip ir reikia. Privatus potinklis čia panaudotas, nes tai nėra normali interneto svetainė, o tik IE atidaroma vizualizacija, kruopščiai izoliuota ir apsaugota nuo išorinio tinklo.
