Dabar yra 2026 06 04, 15:16. Visos datos yra GMT + 2 valandos.
 Forumas » Garso aparatūra » Kokia geriausia deze subams,jos tipas?
PranešimasParašytas: 2006 07 20, 21:49 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Simsius
Idea
PranešimasParašytas: 2006 07 20, 21:57 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sigius
Uzdaro tipo - kokybei
Uzdaro tipo su faziku - sokiai tokiai kokybei ir slegiui
BrandPass - slegiui
PranešimasParašytas: 2006 07 20, 22:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
leopard
Different types of boxes will produce different types of bass:
Sealed boxes: For deep, precise bass
A sealed box is an airtight enclosure housing your subwoofer. A sealed box is best for any music that demands tight, accurate bass. Expect flat response (not excessively boomy), deep bass extension, and excellent power handling. Since a sealed enclosure tends to require more power than a ported box, use an amplifier with ample wattage for optimum performance.
Ported boxes: For forceful bass
Ported boxes use a vent (called a port) to reinforce low bass response. You get more output than you would from a sealed box at any given amplifier wattage. Some people prefer the sound of ported boxes for rock, heavy metal, or any hard-driving music. Ported boxes can deliver deeper bass than sealed boxes, though they need to be much larger than sealed enclosures to accomplish that.
Bandpass boxes: Maximum slam!
Bandpass boxes are a special type of ported box designed for maximum slam. The woofer is mounted inside a dual-chambered box (one chamber sealed, the other ported), with the sound waves emerging from the ported side. The sound that comes out of the port is extra loud within a narrow frequency range.
Because bandpass boxes are super efficient within that range, they tend to boom. Their aggressive sound is great for rap, reggae, and hard rock. Not all subwoofers work well in bandpass boxes, though; consult our product information or call a Product Advisor to be sure.
Free-air subwoofers
A free-air system consists of woofers mounted to a board attached to the rear deck or placed in the trunk against the rear seat. The trunk of the car acts as an enclosure which houses the subwoofer and isolates sound from the back of the speaker, solving the sound cancellation problem of subs without an enclosure.
Beja... BANDPASS Wink
... http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_enclosures.html ...
