Forumas » Maitinimo šaltiniai » Universalus kroviklis
Universalus kroviklis |
Parašytas: 2016 10 18, 13:33 |
Reiktu kroviklio analogisko siems:
Pirmenybe teikciau:Liitokala Lii500,Liitokala Lii300,Opus BT - C100,Opus BT-C3100 V2.2
Is bedos tiktu:LiitoKala lii-100,LiitoKala Lii - 202,Skilhunt M1 arba XTAR-VC2PLUS ir XTAR-SV2
Yra Lemonoje XTAR-VC4,bet man jis nepatinka.SKYRC MC3000 per brangus
Zinau kad yra pirkt visokiuose aliexpress,Banggood.Noriu rast pirkt Lietuvoje |
Tomas Fuleris |
Re: Universalus kroviklis |
Parašytas: 2016 10 18, 14:30 |
| Zuperis rašo: |
turiu xtar vc2 |
Parašytas: 2016 10 18, 14:33 |
| Jakaz rašo: |
| Zuperis rašo: |
turiu xtar vc2 |
Sita https://www.lemona.lt/?page=item&i_id=221855 ir kaip jis Jums? |
Tomas Fuleris |
Parašytas: 2016 10 18, 14:40 |
| Zuperis rašo: |
| Jakaz rašo: |
| Zuperis rašo: |
turiu xtar vc2 |
pagal išvaizda toks,bet aprašymas gal ne visai toks
Input Power DC 5.0V 1.0A
Max Constant Charging Current 500 ±50mA
Min Constant charging current 150±50mA
Cut-off Voltage(Output Voltage) 4.20V±0.05V
Auto Recharging Threshold Value Voltage 3.9V±0.15V
Cut-off Current ≤80mA
Working Temp 0-40
Net Weight 109g
Dimensions
L131*W66*H33mm
Apply to
Two 10440/14500/14650/16340/17500/17670/18350/18500/18650/ 18700/ 22650/25500/26650 3.6/3.7V Li-ion batteries
The unique features of VC2
Worry-free charging
l Automatically stop charging when complete and restart charging function, can keep the batteries inside the charger overnight.
l Reverse - polarity protection and short circuit protection.
l Smartly indentify short circuit or mis-insertion by showing Err.
l Within 5V USB voltage, the safety voltage ensures your safety.
Experience the high tech
l Identify the real capacity of your batteries.
l Creative LCD screen design displays charging current, battery voltage and charging capacity.
l Three stages of charging (TC-CC-CV) can prolong your batteries life.
l Soft start technology to avoid sudden change high current to prolongs the lifespan of batteries.
l Intelligently identify input power and automatically adjust suitable charging current 0.15A to 0.5A. |
Parašytas: 2016 10 18, 14:45 |
| Jakaz rašo: |
| Zuperis rašo: |
| Jakaz rašo: |
| Zuperis rašo: |
turiu xtar vc2 |
Working Temp 0-40
Net Weight 109g
Dimensions
L131*W66*H33mm
Apply to
Worry-free charging
Uzrasas PLUS tai turbut reiskia kad gali krauti NiMh akumuliatorius.Jei reik kraut tik licio akumus tai geriau VC2 nes rodo daugiau info apie akumus |
Tomas Fuleris |
Parašytas: 2016 10 18, 18:45 |
Gal pradėkit diskutuoti, o ne cituoti "paklodes"?  |
Parašytas: 2016 10 19, 08:39 |
| Zuperis rašo: |
| Yra Lemonoje XTAR-VC4,bet man jis nepatinka. |
Turėjau pusdienį XTAR-VC4, pirktą Lemonoje, bet grąžinau, nes NiMH akumuliatoriams rodė ne talpą, o pieno riebumą. Iškrovus ir įkrovus 750mA AAA akumuliatorių - rodė ~2200mA, o 2200mA akumui - ~220mA. Dėl pastarojo galima sutikti, nes akumuliatoriai ne pirmos jaunystės, bet kaip pirmajam talpa su amžiumi padidėjo?  |
Parašytas: 2016 10 19, 08:57 |
| hencia rašo: |
| Zuperis rašo: |
O kaip su ličio akumais,Irgi talpa netiksliai rodo? |
Tomas Fuleris |
Parašytas: 2016 10 19, 09:11 |
| Zuperis rašo: |
Tuo metu neturėjau, bet užteko, kad NiMH nesamones rodė. |
Parašytas: 2016 10 19, 09:14 |
| hencia rašo: |
| Zuperis rašo: |
Labiausiai norėčiau Opus BT -C 3100 ver.2.2.Buvo Skelbiu.lt po 60,bet jau nėra. |
Tomas Fuleris |
Parašytas: 2016 10 19, 09:48 |
Su visais mokesčiais ir gausis 60  |
Tomas Fuleris |
Parašytas: 2016 10 19, 10:34 |
| tokios smulkmenos 90% lenda be mokesciu. ypac is gearbest'o |
Parašytas: 2016 10 19, 10:43 |
| zaliuks rašo: |
Jei smulkmena ateina is JAV - jie kaina labai saziningai deklaruoja, ir tada muitine labai lengvai priskaiciuoja. Jei neapmokestinama limita virsydavo, man nei karto nepraslydo. Bet jeigu siuncia is EU vidaus - gal kazkas kitaip, europines apmuitinamos patirties neturiu. |
GTA 6 Map,
GTA 6 Vehicles,
GTA 6 Character |
