Dabar yra 2026 06 14, 16:21. Visos datos yra GMT + 2 valandos.
 Forumas » Telefonija, tinklai, ryšio elektronika » bluetooth receiver antenna
PranešimasParašytas: 2016 08 06, 00:56 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
turiu bluetooth receiveri kuris pakankamai neblogai funkcionuoja, bet turi silpna rysi ir megsta striginet. Noriu pameginti pasijungti antena, bet nelabai ismanu kur laidus prisilituoti, gal patarsit
centrinis laidas kaip suprantu turetu lituotis kur tos bangeles, o kur lituoti ekranuojanti laida?
PranešimasParašytas: 2016 08 06, 01:51 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sopkls
In order to use an external antenna, you would have to take following into consideration:
1. Use a coaxial cable with the same impedance as your antenna and your final amplifier at bluetooth end.
2. Cut the trace on the PCB that acts as an antenna
3. Try o match the feed point impedance and the impedance at source by minimally separating the coaxial conductors (center and shield) at either end.
4. Make sure you account for signal loss in the co-axial cable. Use a better cable if you want to reduce the loss.
5. There could be more points to consider apart from the ones above
Being a radio ham, I am familiar with antennas, and know how critical it is to get the CORRECT antenna length, if your signal is going to be efficient.
There is a recognised formula for calculating antenna length/frequency, which is (without going into detail) 300/frequency - i.e. 300/150(MHz) will give you 2 metres.
As Bluetooth devices work at frequencies of around 2450MHz, the formula will give you an antenna length of +/- 12cm.
This figure then has to be divided by 4 to give us a quarter wave antenna, which will be 30mm in length - THIS LENGTH IS CRITICAL!!!
25mm or 35mm will just make it less efficient (Lower range).
PranešimasParašytas: 2016 08 06, 08:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
ok, antena turiu 13cm. bet kur lituot laidus?
PranešimasParašytas: 2016 08 06, 09:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
Ir kas pasikeis, jei 1,5dbi antena pakeisi i 2dbi antena ir pigtaile prarasi 0,5dbi ?
Jei jau nori kazka pakeisti, tai reikia antenos bent 5dbi, kas bus juntamai nepatogu del gabaritu imtuvo puseje, jei jis turi buti mobilus.
Be to, jei atstumas tarp siustuvo - imtuvo vos keli metrai, tai galingesnes antenos uzteks siunciancioje puseje, o tai daznai buna gerokai patogiau.
PranešimasParašytas: 2016 08 06, 09:32 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
Tai antena galiu ir 5dBi nusipirkt. gabarintai nesvarbu nes noriu sumontuot i grotuva. O vat ant siustuvu (laptopo ar telefono) antenu neuzdesi.
Tas imtuvelis buvo plastikineme korpuse, neimanoma buvo naudoti, nors atstumas 2m. Isemus is korpuso nebetrukineja garsas, bet kartais visvien uzeina. Todel manau, kad antena pagelbetu
PranešimasParašytas: 2016 08 06, 09:40 Pranešti apie taisyklių pažeidimą Atsakyti su citata
rimosiuss
o tai pusmetrio atstumu bent veikia gerai?
jei tas pats , tai kazi ar antena cia ka pades..
PranešimasParašytas: 2016 08 06, 10:37 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
kai buvo korpuse reikedavo salia pastatyti kad netrukinetu, be korpuso(visas plastikinis, nera metaloploksteliu ar pan) galiu vaikscioti po visa kambari, bet megsta patrukinet kartais.
Noriu sumontuoti i grotuva, tai vel bus po korpusu, todel noreciau antena isvesti
PranešimasParašytas: 2016 08 06, 10:46 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
Jei BT aparatura tvarkinga, tai patikimai turi veikti minimum 10m atstumu.
Del luzinejimo gali buti kalti maitinimo nestabilumas, tad prilituok koki elektrolita 10..47uF lygiaireciai 0,1uF kondensatoriui, o jei ir jo nera, tai ir keramini 0,1uF kondensatoriu prilituok.
PranešimasParašytas: 2016 08 06, 10:49 Pranešti apie taisyklių pažeidimą Atsakyti su citata
S_Kulikauskas
Regis777 rašo:
Tiek bluetooth, tiek WiFi, tiek įvairaus plauko radijo stotelės tai dvipusio ryšio įrenginiai. Kitaip sakant abi pusės turi ir siūstuvus ir imtuvus ir jei signalas stringa bent į vieną pusę, normalaus ryšio neturėsi.
O kalbant apie antenas, visi radijo mėgėjai puikiai žino, kad jos kaip įrenginys signalo nestiprina, jos tik "koncentruoja" anteninį lauką kuria nors kryptimi, kitaip sakant tu išgaudamas didesnį nuotolį viena kryptimi, mažini kitomis kryptimis. O man regis tokiam prietaisui, kaip bluetooth visgi praktiškiau naudoti "Isotropic" tipo antenas.
PranešimasParašytas: 2016 08 06, 10:57 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
AlgisL rašo:
cia ta prasme prie maitinimo?
PranešimasParašytas: 2016 08 06, 10:59 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
S_Kulikauskas rašo:
Kodel tada tas prietaiselis toks jautrus uzdengimui? net pirtais uzdengus prie antenos rysys truksta
PranešimasParašytas: 2016 08 06, 11:05 Pranešti apie taisyklių pažeidimą Atsakyti su citata
rimosiuss
Regis777 rašo:
na antena matyt reiketu jungti nupjovus takeli (tos gyvateles) pacioj pradzioj .ty prie tos kilpos. ir toj pat vietoj kilpoj prilituoti ketvircio ar puses bangos ilgio drata. siaip gali pabandyti pasimatuoti tos gyvateles ilgi ir prijungti tiesu tokio pat ilgio drata , kuri ir iskisi per korpusa. nors keistoka , kaip plastikinis korpusas daro toki poveiki. nors aisku gali , buti kad isderina anteneles suderinimo grandine , o ne kazka ekranuoja . bet tai suzinosi tik prijunges ta drata.
PranešimasParašytas: 2016 08 06, 11:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
S_Kulikauskas
Neturiu, ką pasakyti Laughing , tikriausiai todėl, kad pirštai nelaidūs bangoms Smile .
Čia apie antenų kryptingumą, penkiais sakiniais: https://drive.google.com/open?id=0B6EeGS6PVCUFUlJRNXgtY3RfSm8
Gal kas nors kitas įmes tau atsakymą apie pirštus Smile .
PranešimasParašytas: 2016 08 06, 17:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Regis777
rimosiuss rašo:
hmm.. panašu, kad padėjo Very Happy Ačiū
