 2026 m. balandžio 26 d. Projektas | Reklama | Žinokite | Klausimai | Prisidėkite | Atsiliepimai | Kontaktai
Dabar yra 2026 04 26, 00:45. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » Atmega16 fuses nustatymai
PranešimasParašytas: 2016 04 16, 17:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
laidback
Darau is zurnalo winamp'o valdyma. Proteus simuletoriui programa pasileidzia ir lcd uzsidega "welcome" pasveikinimas, o realybei ant lcd tik dega visa eilute ir daugiau nieko. Gal blogi fuse nustatymai? Naudoju Atmega16A.
Kodas:
Kodas:
'ATmega16
$hwstack = 128
$swstack = 128
$framesize = 128
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , Rs = Portc.0 , E = Portc.1       'LCD 16*2
$baud = 9600
$crystal = 8000000                                          'Internal clock
Declare Function Getad() As Byte
Config Adc = Single , Prescaler = Auto , Reference = Aref
Dim Last As Word
Dim Value As Byte , Temp As Byte , Send As Byte , Diff As Integer , Cn As Byte
Dim Tmp As Byte
Dim Tex(40) As Byte                                         'Text memory
Config Portd.3 = Output                                     'Button setup
Config Portd.5 = Output
Config Portd.6 = Output
Config Porta.0 = Input
Config Porta.1 = Input
Config Porta.2 = Input
Config Porta.3 = Input
Set Porta.0
Set Porta.1
Set Porta.2
Set Porta.3
Tas1 Alias Pina.0                                           'Button 1
Tas3 Alias Pina.1                                           'Button 2
Tas4 Alias Pina.2                                           'Button 3
Tas2 Alias Pina.3                                           'Button 4
En Alias Portd.3                                            'Enable output for L293D
A1 Alias Portd.5                                            'Output 1 of L293D
A2 Alias Portd.6                                            'Output 2 of L293D
Last = 250
Cursor Off                                                  'LCD init
Cls
Lcd " Winamp Control"
Lowerline
Lcd " v.1.1"
Locate 1 , 1
New:
Waitms 100
Newi:
Temp = Udr                                                  'Read serial input
Value = Getad()                                             'Start position
Do
   Temp = Getad()                                           'Current position
   Diff = Value - Temp
   Diff = Abs(diff)
   If Diff > 5 Then                                         'Manual move?
      Goto Manual
   End If
   If Tas1 = 0 Then                                         'Button 1 pressed?
      Do
         Waitms 100
      Loop Until Tas1 = 1
      Printbin 251
      Printbin 0
   End If
   If Tas2 = 0 Then                                         'Button 2 pressed?
      Do
         Waitms 100
      Loop Until Tas2 = 1
      Printbin 252
      Printbin 0
   End If
   If Tas3 = 0 Then                                         'Button 3 pressed?
      Do
         Waitms 100
      Loop Until Tas3 = 1
      Printbin 253
      Printbin 0
   End If
   If Tas4 = 0 Then                                         'Button 4 pressed?
      Do
         Waitms 100
      Loop Until Tas4 = 1
      Printbin 254
      Printbin 0
   End If
   Temp = Inp(&H2b)                                         'Serial data received?
   Temp = Temp And &B10000000
Loop Until Temp > 0
Value = Udr                                                 'Process data
Sync:
If Value = 125 Then Goto Textd                              'Command 125 -> receive data and set LCD
Send = 140
If Value = 120 Then Send = 100                              'Valid command?
If Value = 110 Then Send = 0
If Send = 140 Then Goto New
Do
   Temp = Inp(&H2b)                                         'Wait for second data byte
   Waitms 1
Loop Until Temp > 0
Value = Udr
If Value > 101 Then Goto Sync                               'Error
Send = Send + Value                                         'Check data
If Send > 200 Then Send = 200
Send = 200 - Send
Value = Getad()
Diff = Value - Send                                         'Diference between leaver and received value
Diff = Abs(diff)
If Diff < 5 Then Goto New                                   'Difference to small return
If Value > Send Then                                        'Drive leaver up
   Temp = Getad()
   If Temp = 0 Then Goto Endpush
   Cn = 0
   Value = Getad()
   Reset A1
   Set A2
   Set En
   Do
      Temp = Getad()
      If Value < Temp Then Goto Manual
      If Value = Temp Then
         Cn = Cn + 1
         If Cn = 250 Then Goto Manual
      Else
         Cn = 0
      End If
      Value = Temp
   Loop Until Temp =< Send Or Temp = 0
   Goto Endpush
Else
'############################################################################### 'or drive leaver down
   Temp = Getad()
   If Temp = 200 Then Goto Endpush
   Cn = 0
   Value = Getad()
   Set A1
   Reset A2
   Set En
   Do
      Temp = Getad()
      If Value > Temp Then Goto Manual
         Cn = Cn + 1
      Else
         Cn = 0
      End If
      Value = Temp
   Loop Until Temp => Send Or Temp = 200
   Goto Endpush
End If
Endpush:
   Reset En
Goto New
Textd:                                                      'Receive 32 bytes for display
Tmp = 1
   For Cn = 1 To 32
         Do
           Waitus 50
           Temp = Inp(&H2b)
         Loop Until Temp > 0
         Tex(cn) = Udr
   Next Cn
Tmp = 1
Locate 1 , 1
For Cn = 1 To 32
   If Tex(cn) > 32 And Tex(cn) < 127 Then
      Lcd Chr(tex(cn))
   Else
      Lcd " "
   End If
   If Tex(cn) = 0 Then Goto Newi
   If Cn = 16 Then
      Locate 2 , 1
   End If
Next Cn
Goto Newi
Manual:                                                     'Manuall override
   Printbin 240                                             'Notifie PC that leaver was pushed manual
   Printbin 0
Manualt:
   Reset En
   Value = Getad()
   Waitms 250                                               'If leaver stood dtill for 250ms then notifie PC
   Temp = Getad()
   If Value <> Temp Then Goto Manualt
   Temp = 200 - Temp
   Temp = Temp + 1
   Printbin Temp
   Printbin 0
Goto New
   Local A As Word , B As Integer
   A = Getadc(4)
   A = A / 5.12
   If A > 200 Then A = 200
   If A < 0 Then A = 0
   If A = 0 Or A = 200 Then
      Last = A
      Goto Exget
   End If
   B = A - Last
   B = Abs(b)
   If B < 5 Then
      A = Last
      Goto Exget
   End If
   Last = A
Exget:
   Getad = A
End Function
Fuses:
Patarkit ka dar perziuret.
PranešimasParašytas: 2016 04 16, 18:04 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
Zvilgtelk http://www.engbedded.com/fusecalc/ ir nusistatyk kaip reikia
Kad Atmega veiktu 8MHz dazniu, tau reikia nustatyti CKSEL0 bei nuimti CKSEL2 varnas.
Abejoju ar tau reikia JTAGEN
Manau, kad praverstu BODEN, o BODLEVEL priklauso nuo kiek maitini Atmega (jei nuo 5V, tai gali uzdeti varna).
PranešimasParašytas: 2016 04 16, 18:45 Pranešti apie taisyklių pažeidimą Atsakyti su citata
laidback
Dekui uz gero linko priminima, viskas susitvarke.
PranešimasParašytas: 2016 04 16, 19:56 Pranešti apie taisyklių pažeidimą Atsakyti su citata
S_Kulikauskas
Gaila,kad pas mus nėra"Laik" mygtuko, Laidback jau spaustų, o aš spausčiau du kart, už tai kad žmogus, aukodamas savo laiką tokius gerus patarimus dalina Wink .
