Dabar yra 2026 06 02, 20:13. Visos datos yra GMT + 2 valandos.
 Forumas » Garso aparatūra » 24K gold plated?
 24K gold plated?
PranešimasParašytas: 2016 01 02, 23:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
minde7706
Sveiki, Su Naujais Metais visus!
Nusipirkau RCA Shark kistukus is Maplins UK ( jau iseme is prekystalio) aprasyme buvo parasyta 24K gold plated. Mano supratimu tai turetu buti auksu dengta.
Darbe as naudojuos tokiu analizatoriumi http://www.thermoscientific.com/content/tfs/en/product/niton-xl2-xrf-analyzer.html
Praskanavus, pasirode kad ten jokio aukso nera. Nikelio 25%, vario 47%, zinko 24% ir dar truputeli kitu element, bet ne aukso.
Gal kas buvote susidure?
Aisku db teks ieskoti kitu alternatyvu, ir butinai skanuosiu Smile
Sorry jei idejau posta I nettinkama skilti.
DIY SE EL34, DIY phono stage "grovewatt", Lowther Acousta DX2, Thorens TD160 (Denon DL110), DAC END 24.
 24K gold plated?
PranešimasParašytas: 2016 01 02, 23:57 Pranešti apie taisyklių pažeidimą Atsakyti su citata
obalys
"Gold plated jewelry is NOT gold jewelry. Gold plated jewelry is jewelry made of a base metal (e.g. copper) or silver that has a very thin layer of gold applied to the top. The layer is so thin, that it can usually be rubbed off with a coarse pencil eraser in a few swipes. Some plated jewelry has a “thicker” layer of gold than other plated jewelry, but the difference is insignificant on the grand scale of things. When buying gold plated jewelry, you should consider the gold plating as nothing more than a coloring (an aesthetic attribute) – there is almost no inherent value to the gold applied. It doesn’t matter if it’s 24K, 14K or 18K."
http://blog.hunterridgejewelry.com/the-difference-between-gold-gold-plated-and-gold-filled-jewelry/
Pirma pasidomėk kas tai yra, o tik paskui pirk, tada nereiks lieti abydos kad tave apgavo Very Happy
 24K gold plated?
PranešimasParašytas: 2016 01 03, 00:02 Pranešti apie taisyklių pažeidimą Atsakyti su citata
minde7706
Skaneris skanuoja tik pavirsiu, esu skanaves tukstancius pavirsiu. teko ir ne viena zieda vestuvini kolegom skenuoti. ziedai parodydavo atitinkama procenta aukso sudetyje. taciau RCA jungtyse nerodo jokio aukso. Man tik idomu ar jums teko susidurti.
Ieskosiu rimtesniu RCA jungciu is patikimesniu tiekieju...
 24K gold plated?
PranešimasParašytas: 2016 01 03, 00:18 Pranešti apie taisyklių pažeidimą Atsakyti su citata
obalys
Tai jeigu ten užnešta keli mikronai storio aukso dulkių kokių procentų tu ieškai? Tavo aparac rodo bent du nulius po kablelio? Ir šiaip audio aparatūroj tas "gold plated" ...filams viliot. Jei nori tikro rezultato - nešk pas juvelyrą ir turėsi. Asmeniškai mano nuomone yra kitų vietų, kur reikėtų investuoti pinigus kad išgirstum ryškesni garso skambesio skirtumą (nesakau pagerėjimą, nes jį visi suprantam skirtingai).
 24K gold plated?
PranešimasParašytas: 2016 01 03, 00:36 Pranešti apie taisyklių pažeidimą Atsakyti su citata
minde7706
Skaneris kainavo virs 25000£, nemanau kad jis meluoja, nupirksiu is hificolective RCA jungti ir praskanuosiu...
 24K gold plated?
PranešimasParašytas: 2016 01 03, 00:51 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vardas11
Ir ką tas aukso paviršius duos jei toliau signalas kitais metalais tekės? Suprasčiau jei visas kištukas būtų iš gryno aukso Smile
 24K gold plated?
PranešimasParašytas: 2016 01 03, 09:30 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kwlw
vardas11 rašo:
Auksas dėl savo nenoro oksiduotis ir plastiškumo - užtikrina geresnį kontaktą, jei visa grupė kištukas-lizdas paauksuota. Nežinau ar jo trūksta RCA jungtim, bet senais laikais auksuodavo lempų kojas būtent dėl to. Taip pat dėl to auksuodavo ir kompų jungtis, procesorių kojas ir lizdus. Dabar, beje irgi dar yra kažkiek aukso dedama į kai kurias pramonines jungtis.
Taip, kad nenurašykit taip jau to aukso Smile. Jis - ne tik krūtiem cepam tinkamas, bet dar ir kaip technologinis metalas - visai nieko Smile.
Sau
 24K gold plated?
PranešimasParašytas: 2016 01 03, 09:58 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Osmis
obalys rašo:
Teisingai pastebėta, jei ir dengta tai labai jau plonu sluoksniu ir analizatorius matyt nelabai ką tenuskanuoja. O nešti tokias jungtis reik ne pas juvelyrus o į galvanikos cechą, ten gali ir storesniu sluoksniu padengti Wink
kwlw rašo:
vardas11 rašo:
Sau
Kaip teisingai "kwlw" pastebėjo auksas naudojamas ne tik kaip juvelyrinis bet ir kaip technologinis metalas - jungtyse, rėlių kontaktuose ir t.t. Bet dažniausiai tai naudojama aukštadažnėje technikoje, o ar tai duos kokį efektą ŽD srityje drįsčiau abejoti, nes kaip žinia auksas "dėvisi" ir dažnai traukant tuos kištukus jo sluoksnis tiesiog nudils.
p.s. truputi ne į temą, bet bendram išprusimui gal bus įdomu, seniau bankų saugyklose, kuriose laikydavo aukso luitus, darydavo medines grindis, kad po kiek laiko jas galėtu sudeginti ir iš pelenų išlydyti aukso dulkes.
 Re: 24K gold plated?
PranešimasParašytas: 2016 01 03, 10:49 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vaidas2
minde7706 rašo:
Pabandyk pas čigonus Mr. Green
 24K gold plated?
PranešimasParašytas: 2016 01 03, 11:11 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vardas11
Dėl geresnio kontakto sutinku, tik turbūt jei normalus, neišdilęs, kištukas ir lizdas, tas kontakto plotas ir taip labai nemažas ir didesnė varža pačiam laide, o ne kištuko kontakte. Ar aš klystu?
Kitas reikalas kai kištukas jau padilęs ir kontaktai galbūt nevisam plote susiliečia, jei tik to aukso tada dar būna likę.
 24K gold plated?
PranešimasParašytas: 2016 01 03, 11:34 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vardas11 rašo:
Taip, klysti labai. Ir esmė čia visai ne varžoje. Metalas padengtas oksidu įgauna puslaidininkio savybes, todėl apsioksidavę kontaktai veikia kaip diodas. Iš to atsiranda iškraipymai. Auksas - nesioksiduoja. Nors sidabras - geresnis laidininkas už auksą, bet kontaktams naudojamas būtent auksas. (elektrotechnikoje naudojamas sidabras, bet ten kiti reikalavimai kontaktams)
Visai neseniai taisiau stiprintuvą kurio įėjimo komutatoriaus jungiklio kontaktai buvo stipriai oksidavęsi, patikėk iškraipymai tokie žiaurūs, kad iš pradžių įtariau galinio laipsnio gedimą. Nuvalius kontaktus iškraipymai dingo.
Dėl tos pačios priežasties garso stiprintuvai esantys netoli galingų AM radijo stočių groja tai ką jos transliuoja - kontaktai veikia kaip detektorius.
 24K gold plated?
PranešimasParašytas: 2016 01 03, 12:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vardas11
Evaldas_S rašo:
vardas11 rašo:
Supratau, dėkui už išsamų atsakymą.
 24K gold plated?
PranešimasParašytas: 2016 01 03, 13:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
minde7706 rašo:
su kuo?
su auksu ant kinietiškų kištukų?
ne, neteko, ir esu tikras, kad neteks Smile
PranešimasParašytas: 2016 01 03, 16:11 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ernix
minde7706 rašo:
Baik juokauti, tokiu analizatoriumi, tokių aukso kiekių tikrai neužčiuopsi. Yra analizatoriai kainuojantys apie 50000 eurų, kurie yra nepalyginamai tikslesni, ir tai klausimas ar tais duomenimis, šiuo atveju verta remtis.
 24K gold plated?
PranešimasParašytas: 2016 01 04, 01:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
VEC7OR
minde7706 rašo:
Ir kas? Ar kaina turi kazko bendro su specifikacija ir jo galimybe atpazint keliu mikronu aukso sluoksni.
Dabar griztant prie aukso ir paauksavimu - o kam? Neturim kur bapkes det ?
Jei reikia kokybisku RCA jungciu - vat gamintojai, kaina apie 1.5-3eu uz vnt, kokybe superine, jokiu nesamoniu.
http://www.rean-connectors.com/en/products/phono-plugs/
http://www.neutrik.com/en/phono-rca/profi-cable-connectors/nf2c-b-2
http://www.amphenolaudio.com/products/rca/cable-connectors/m-series/
Dar gali paziet Pomona ir Switchcraft. Uzsakyt galima per Lemona is Farnell arba Mouser.
Visa kita yra masturbacija ir pinigu svaistymas, taip galima cia filosofuot apie auksas vs. rodis, bet tada kila daug kitu klausymu - kur nauduojama, kokios salygos, etc etc, nes buityje - jei trumpai - nesvarbu, nes tas pats iprastas nikeliavimas nesioksiduoja niekada, o sujungimo ciklas nuvalo beveik viska kas galetu trukdyt geram kontaktui.
