Dabar yra 2026 05 12, 07:40. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » LED matrica 64x32
 LED matrica 64x32
PranešimasParašytas: 2015 05 30, 14:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
dmb-220
sveiki, isigijau matrica, ir programuojant pagal duota koda iskilo problemu.
Kodas:
Kodas:
// Routine to print a single character in one of 8 columns
// Inputs:
// x is one of (0,16,24,32,40,48,56),
// y (0 to 16 or 24 depending upon font size),
// n is either (0 to 9) or an ascii value,
// font=0 for big font, 2 for small font,
// inverse is true for an inverted character
void drawChar(uint16_t x, uint16_t y, byte n, byte font, boolean inverse) {
    byte charbytes[16], fontrows, xover8 = x>>3;
    int index;
    if (0 != (x % 8)) return;    // x not a multiple of 8
    if ((n>9) && (n<32)) return; // invalid character
    if (font==2) fontrows=16; else fontrows=8;
    if ((n>=0) && (n<=9)) index=(n+16)*fontrows; else index=(n-32)*fontrows; // go to the right code for this character
// addressing start at buffer and add y (rows) * (WIDTH is 64 so WIDTH/8) is 8 plus (x / 8) is 0 to 7
    byte *pDst = buffer + (y << 3) + xover8;
    for (byte i=0;i<fontrows;i++) {  // fill up the charbytes array with the right bits
      if (font==0) charbytes[i] = pgm_read_byte(&(font8x8_basic[index+i]));
//      if (font==1) charbytes[i] = pgm_read_byte(&(font8x8_extended[index+i]));
      if (font==2) charbytes[i] = pgm_read_byte(&(font8x16_basic[index+i]));
      // reverse bit order for fonts 0 and 1
      if (font != 2) {
        charbytes[i] = (charbytes[i] & 0xF0) >> 4 | (charbytes[i] & 0x0F) << 4;
        charbytes[i] = (charbytes[i] & 0xCC) >> 2 | (charbytes[i] & 0x33) << 2;
        charbytes[i] = (charbytes[i] & 0xAA) >> 1 | (charbytes[i] & 0x55) << 1;
      if (inverse) charbytes[i] = ~charbytes[i];
    const byte *pSrc = charbytes; // point at the first set of 8 pixels
    for (byte i=0; i<fontrows; i++) {
        *pDst = *pSrc;     // populate the destination byte
        pDst += 8;         // go to next row on buffer
        pSrc++;            // go to next set of 8 pixels in character
visa matrica jei nieko neatvaizduoju sviecia visi ledai, ten kur raides ar skaiciai jie nedega, o as noriu kad sviestu tik tie led kur raides ar skiciai atvaizduojami, o visa kita nedegtu. ir nesuprandu ka sitojme kode pakeisti kad butu kaip noriu, yra funkcija inverse bet ji tik pacia raide pakeicia ir aplink ja, jei raide 8x8 tai sita plota ir keicia, o visa kita ne, as noriu kad visa pasikeistu. jei kam nesunku pagelbekit
Skype: dmb-220
 LED matrica 64x32
PranešimasParašytas: 2015 05 30, 14:35 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
atkreipk i proceduros parametra inverse
 LED matrica 64x32
PranešimasParašytas: 2015 05 30, 14:56 Pranešti apie taisyklių pažeidimą Atsakyti su citata
dmb-220
AlgisL rašo:
jei tu turi omenyje sita eilute
Kodas:
tai ji nustatinejau ir i true ir i false ir apie tai rasiau
visas kodas : https://drive.google.com/file/d/0B7l6SxJ3dkyCTzlwZkVXeWdvbk0/view?usp=sharing
pavyko pasidaryt kad visa matrica nesvietu, o svietu tik uzrasai, ivertavau visa buffer kintamaji su ~
PORTB |= !((~buffer[index]>>(7-i)) & 0x01) << (data_R1-Cool; // top set of rows
PORTB |= !((~buffer[index+128]>>(7-i)) & 0x01) << (data_R2-Cool; // bottom set of rows
as galvoju kad cia viska as per aplinkui darau, reik rasti kode kur iskart yra padaromas visa sviecianti matrica ir ja isjungti, tik nerandu, ir visa buferi invertuoju kad padoriai rodytu. kazkur kode kur nera raidziu ir pan programa i bufferi sukisa vienetus ir taip sviecia visa matrica, tik nerandu ir nesuprandu kurioje vietoje. man biski kosmosas bytu postumiai greitai pasimetu kur kas turi buti, gal kas kokia technika gera turit kad nepasimest
Skype: dmb-220
