Dabar yra 2026 05 12, 08:22. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » arduino kodas ir tekstas ant lcd
PranešimasParašytas: 2015 05 20, 05:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
Arduino thermistor example software
Tutorial: http://www.hacktronics.com/Tutorials/arduino-thermistor-tutorial
Copyright (c) 2010 Mark McComb, hacktronics LLC
License: http://www.opensource.org/licenses/mit-license.php (Go crazy)
#include <LiquidCrystal.h>
#include <math.h>
LCD Connections:
rs (LCD pin 4) to Arduino pin 12
rw (LCD pin 5) to Arduino pin 11
enable (LCD pin 6) to Arduino pin 10
LCD pin 15 to Arduino pin 13
LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13; // pin 13 will control the backlight
void setup(void) {
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
lcd.begin(20, 4); // rows, columns. use 16,2 for a 16x2 LCD, etc.
lcd.clear(); // start with a blank screen
lcd.setCursor(0,0); // set cursor to column 0, row 0
double Thermister(int RawADC) {
double Temp;
// See http://en.wikipedia.org/wiki/Thermistor for explanation of formula
Temp = log(((10240000/RawADC) - 10000));
Temp = 1 / (0.001129148 + (0.000234125 * Temp) + (0.0000000876741 * Temp * Temp * Temp));
Temp = Temp - 273.15; // Convert Kelvin to Celcius
return Temp;
void printTemp(void) {
double fTemp;
double temp = Thermister(analogRead(0)); // Read sensor
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Temperature is:");
lcd.setCursor(0,1);
lcd.print(temp);
lcd.print(" C / ");
fTemp = (temp * 1.Cool + 32.0; // Convert to USA
lcd.print(fTemp);
lcd.print(" F");
if (fTemp > 68 && fTemp < 7Cool {
lcd.setCursor(0,1);
lcd.print("Very comfortable");
void loop(void) {
printTemp();
delay(1000);
Turiu sita koda is cia http://www.hacktronics.com/Tutorials/arduino-thermistor-tutorial.html paveiksleli matos naudojamas 4 segmentu lcd o pas mane tik 2. Pakeiciu lcd.setCursor i 0,1 prie if salygos tada pradeda rodyt ta sakini lcd.print("Very comfortable"); kaip padaryt kad suveikus if parodytu sita sakini o poto vel temperatura, nes lcd tik 2segmentu, o projektas su 4 segmentais.
Paskutinį kartą redagavo super, 2015 05 20, 20:49. Redaguota 1 kartą
PranešimasParašytas: 2015 05 20, 08:24 Pranešti apie taisyklių pažeidimą Atsakyti su citata
mindogas
Kai kita karta eisi i tualeta didelio reikalo pagalvok dar karta apie sia problema, gal sprendimas ateis pats i galva. Pastumdyti ka po ko spausdini tikrai neturetu buti sunku tikram programuotojui.
PranešimasParašytas: 2015 05 20, 10:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
Mano C ziniom tai persudetinga.
PranešimasParašytas: 2015 05 20, 12:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ingo
O tu nurodei kad pas tave 16x2 lcd?
t.y. lcd.begin(16, 2);
PranešimasParašytas: 2015 05 20, 12:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
Ingo rašo:
Nu ir kas vistiek ta pati rodis, nes viska rodo tai pat kaip nuotraukoj tik kai lcd 16x2 o ne 16x4 tai tas uzrasa turinti but 3 eilutei perkeliau i 2 eilute bet tada rodo tik ji, tai galvoju kad ji butu galima keist kas kelias s su temp parodimais
PranešimasParašytas: 2015 05 20, 13:49 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ingo
Kad tu nesupranti elementariu dalyku, pasziurek ir suprask ka daro printTemp funkcija.
Si f-ja pirmoje eiluteje isveda uzrasa, antroje eiluteje, skaitines reiksmes, o paskui dar papildomai "Very comfortable", o tu sita "Very comfortable", padarai su savo lcd.setCursor 0,1 vel iskarto dedi i antra eilute, tai pries dedamas padaryk koki delay(3000); ,kad spetum pamatyt kas buvo antroje eiluteje,ir man atrodo kad tuomet geriau butu lcd.setCursor(0,0);, tai bent skaitines reiksmes pastoviai matytusi
PranešimasParašytas: 2015 05 20, 15:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
Ingo rašo:
Tai man ir reikia kad laipsnius ir uzrasa rodytu is eiles, o kas bus parasius 0,0 ?
PranešimasParašytas: 2015 05 20, 17:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ingo
Nu as nebesuprantu ko tu nesupranti ir kaip tau paaiskinti!
parasius 0,0 nieko nebus, o parasius
lcd.setCursor(0,0); bet kuris tekstas einantis po sios eilutes bus pradedamas rasyti lcd pirmoje eiluteje nuo pirmo langelio, taciau priestai buves tekstas sioje eiluteje bus momentaliai istrinamas jeigu nepadarysi delay.
PranešimasParašytas: 2015 05 20, 17:22 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Socrates
Sekantis klausimas bus: "kodel man viska rodo Farenheitais?"... Reiktu trint sita tema, nes cia bergzdzias reikalas isvis kazka diskutuot su juo Laughing Po kokiu 5 metu gal kazkoks suvokimas ir ateis pas ji.
PranešimasParašytas: 2015 05 20, 20:48 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
Ingo rašo:
Siulot man ikist delay pries very comfortable, bet taip netinka, tarkim temp pakyla iki 18 laipsniu, tai ka as pastovei zesiu i temp, kad pamatyt kokia buvo temperatura ?
PranešimasParašytas: 2015 05 20, 21:04 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ingo
super rašo:
Nieko nesupratau ka cia parasei, surasyk viska paeiliui kaip pagal tave programa turetu veikti, kokia 10-20 eiluciu, gal tada bus aiskiau.
PranešimasParašytas: 2015 05 21, 15:53 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
https://www.youtube.com/watch?v=V2GL3DIOttg Noriu padaryt kaip cia kad keistu uzrasai, komentare duotas kodas, bet nzn i kurias kodo eilute zet jo kode.
PranešimasParašytas: 2015 05 21, 17:38 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ingo
Tai tu nori matyti temperatūros kitimo istorija?
PranešimasParašytas: 2015 05 21, 17:58 Pranešti apie taisyklių pažeidimą Atsakyti su citata
super
Ta prasme as negaliu matyt temp nuo 25 laipsniu, nes ja pakeicia uzrasas, tai noriu, kad uzrasas keistu su laipsniais nes jie vienoj eilutej.
PranešimasParašytas: 2015 05 21, 19:28 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ingo
Jug aiskinau, perrašyk pora eilučių:
pakeisk lcd.begin(16, 2); ir vietoje lcd.setCursor(0,3); įrašyk:
delay(3000);lcd.setCursor(0,0);
