Dabar yra 2026 05 01, 14:53. Visos datos yra GMT + 2 valandos.
Forumas » Mikrovaldikliai » Padekit Su C++ Picams. Nesuprantu kaip panaudoti klavetura
Padekit Su C++ Picams. Nesuprantu kaip panaudoti klavetura |
Parašytas: 2006 04 25, 18:00 |
Codas nemano rasytas. bet ir as nelabai kertu. Pradedu po biski tik
* June 4, 2003 CONFIG statement changed to prevent errors with version 8 compiler
* lcdterm6.c December 4, 2000 Bob Blick
* Licensed under the terms of the GNU General Public License, www.gnu.org
* No warranties expressed or implied.
* Full duplex serial terminal using an LCD character display(HD44780 compatible),
* matrixed keypad up to 20 switches, and a PIC16F84
* This version adds super-multiplexing on upper 5 bits of PORTB, input and output!
* Minor bugfix to serial receive, centers better on bits now.
* compile with PICCLITE from www.htsoft.com
* command line:
* picl -O -Zg9 -16F84 -V lcdterm6.c
* pin assignments:
* PORTA 4 p3 3 p2 2 p1 1 p18 0 p17
* SERIN KBI3 KBI2 KBI1 KBI0
* PORTB 7 p13 6 p12 5 p11 4 p10 3 p9 2 p8 1 p7 0 p6
* LCD7 LCD6 LCD5 LCD4 LCDRS LCDEN SEROUT BKLITE,
* KBDO7 KBDO6 KBDO5 KBDO4 KBDO3 BEEP, WHATEVER
* OTHER p5 p14 p4 p15 p16
* Vss/GND Vdd/+5 /MCLR OSC2CKO OSC1CKI
#include <pic.h>
//__CONFIG(WDTDIS & HS & UNPROTECT); //this is for HS (more than 4 megahertz) oscillator
__CONFIG(WDTDIS & XT & UNPROTECT); //this is for XT (4 megahertz or less) oscillator
// Watchdog timer would be | 0x04 but I'm not using it
// Change these to suit your setup
// You must use one and only one of the next four
#define CURSOR_OFF_NOBLINK //if you want no cursor
//#define CURSOR_ON_NOBLINK //if you want a plain cursor
//#define CURSOR_OFF_BLINK //if you want the print position to blink
//#define CURSOR_ON_BLINK //the cursor kitchen sink
// LCD formatting does line wraps correctly. Uses memory, you don't need it unless you want it.
// Note that 2X40 displays wrap correctly right out of the box and need no formatting.
#define LCD_FORMAT //if you want LCD line formatting uncomment this
// If you chose LCD_FORMAT uncomment one and only one of the following
#define LCD_4X20 //if you have a 4x20 display and want formatting
//#define LCD_2X20
//#define LCD_2X16
//#define LCD_2X8 //this also works for cheap 1X16 displays that have one chip
//#define LCD_1X16
// LCD hardware initialization. Two line 5x7 font is the most common. You must choose one.
#define TWOLINE_5X7
//#define ONELINE_5X7 //this gives a better contrast ratio but only on one line displays
//#define ONELINE_5X10 //Many of the better 1 line displays support this.
// Uncomment to Translate ascii to use the full descender versions in the character map
//#define DESCENDERS //if you use 5X10 font you can translate j,y,etc but uses memory
#define XTAL 4000000 // Crystal frequency (Hz).
#define BRATE 2400L // Baud rate. "L" prevents truncation in calculations.
#define RX_OVERSAMPLE 4 // Receive oversampling. Must be at least 4 and power of two
// Super-multiplexed outputs(upper 5 bits) of PORT B get set to this at startup
#define SUPER_MX_OUT_INIT 0b00000000 //lower three bits ignored
/**********YOU DON'T NEED TO CHANGE ANYTHING BEYOND THIS POINT************/
// Keeping you honest
#if (RX_OVERSAMPLE-1)&RX_OVERSAMPLE
#error RX_OVERSAMPLE_value must be a power of 2
#endif
#if (RX_OVERSAMPLE < 4)
#error RX_OVERSAMPLE must be 4 or greater
#endif
#define RX_BITCENTER ((RX_OVERSAMPLE/2) - 1)
#define byte unsigned char
// LCD pins
static bit LCD_RS @ ((unsigned)&PORTB*8+3); // Register select
static bit LCD_EN @ ((unsigned)&PORTB*8+2); // Enable
// Transmit and Receive port bits
static volatile bit TxData @ (unsigned)&PORTB*8+1; /* bit1 in port B */
static volatile bit RxData @ (unsigned)&PORTA*8+4; /* bit4 in port A */
// Don't change these
#define TIMER_VALUE (XTAL / (4 * BRATE * RX_OVERSAMPLE))
#define TRANSMIT_NUM_BITS 13 // 1 start bit + 8 data bits + 2 stop bits + safe.
#define INT_PERIOD (1000000 / (BRATE * RX_OVERSAMPLE)) //that is in microseconds
#if ((TIMER_VALUE) < 90)
#error baud rate or oversample too high for crystal speed
#endif
#if ((TIMER_VALUE) > 256)
#error baud rate or oversample too low for crystal speed
#endif
// Line lengths for LCD formatting
#define BEGIN_LINE_1 0
#define LINE_1_MINUS_1 255
#ifdef LCD_4X20
#define END_LINE_1 19
#define BEGIN_LINE_2 64
#define END_LINE_2 83
#define BEGIN_LINE_3 20
#define END_LINE_3 39
#define BEGIN_LINE_4 84
#define END_LINE_4 103
#define LINE_2_MINUS_1 63
#define LINE_3_MINUS_1 19
#define LINE_4_MINUS_1 83
#endif
#ifdef LCD_2X20
#endif
#ifdef LCD_2X16
#define END_LINE_1 15
#define END_LINE_2 79
#endif
#ifdef LCD_2X8
#define END_LINE_1 7
#define END_LINE_2 71
#endif
#ifdef LCD_1X16
#endif
// Delay constants used by LCD routines
#define T_120_US (120 / INT_PERIOD + 1)
#if (T_120_US < 2)
#undef T_120_US
#define T_120_US 2
#endif
#define T_1000_US (1000 / INT_PERIOD + 1)
#define LCD_STROBE ((LCD_EN = 1),(LCD_EN=0))
#define KB_TASK_PERIOD (50000 / INT_PERIOD + 1) //50000 usec = 20 per second
#define KB_DELAY_LOAD 10 //kb checks before repeat
#define KB_REPEAT_RATE 2 // about 10 per second
#define KB_NO_KEY 20 //scankb returns this if no key is pressed
// Receiver states.
enum receiver_state {
RS_HAVE_NOTHING,
RS_WAIT_HALF_A_BIT,
RS_HAVE_STARTBIT,
RS_WAIT_FOR_STOP = RS_HAVE_STARTBIT+8
// VARIABLES
static byte sendbuffer; // Where the character to sent is stored.
static byte receivebuffer; // Where the character is stored as it is received.
static bit receivebufferfull; // 1 = receivebuffer is full.
static byte send_bitno;
static byte receivestate; // Initial state of the receiver (0).
static byte skipoversamples; // Used to skip receive samples.
static byte rxshift;
static bit tx_next_bit;
static volatile byte delaycount; //decrements every interrupt if nonzero
static volatile unsigned int kbtaskcount; //decrements every interrupt
static bit kbtaskflag; //goes high when it's time to check the keyboard
byte kbdelaycount; //timer for keypress
byte kbrepeatcount;
byte kboldkey; //last keypress
static bit command_next; //next received character is special lcd data
static byte lcdcommand;
#ifdef LCD_FORMAT
byte cursorpos;
#endif
static byte super_mx_in; //super-multiplexed input PORTB 5 upper bits
static byte super_mx_out; //super-multiplexed output PORTB 5 upper bits
// KEYBOARD LOOKUP TABLES
// Primary keyboard codes
const byte Kb_tbl_pri[] = { 0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,
0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f,0x50,
0x51,0x52,0x53,0x54 };
// Secondary keyboard codes
const byte Kb_tbl_sec[] = { 0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,
0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f,0x70,
0x71,0x72,0x73,0x74 };
// mode 0: Keydown sends primary code, when held repeats primary code after KB_DELAY_LOAD delay.
// mode 1: Keydown sends primary code. Keyup sends secondary code.
// mode 2: Keyup sends primary code unless held longer than KB_DELAY_LOAD delay, send secondary.
// mode 3: Keyup sends primary code unless held longer than KB_DELAY_LOAD delay, send secondary
// code, if held another KB_DELAY_LOAD will do repeats of secondary code.
// a non-existent mode disables a key
const byte Kb_tbl_mode[] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00 }; //must have one extra here
// FUNCTION PROTOTYPES
void init_stuff(void); //sets up interrupt, pins, etc
void rs232_putch(byte c); //puts a byte to serial transmit buffer
byte rs232_getch(void); //gets byte from serial receive buffer
void lcd_clear(void); //clear and home the LCD
void lcd_puts(const byte * s); //put ascii string to LCD
void lcd_putch(byte c); //put one character to LCD
void lcd_goto(byte pos); //positions LCD cursor
void lcd_init(void); //sets up LCD interface
void lcd_putcmd(byte c); //send one byte to LCD command register
void delayMs(byte t); //delays 1 to 255 milliseconds
//void rs232_puts(const byte * s); //put ascii string to serial port, uncomment if you need
byte scankb(void); //returns which key is depressed
void kbrs232(byte key); //normal "keypad to rs232 out" operation
void rs232lcd(byte rec); //sends rs232 received data to LCD or translates if needed
#ifdef LCD_FORMAT
void inc_cursor(void); //increments the LCD cursor past line breaks
void dec_cursor(void); //decrements
#endif
// THE PROGRAM
void main(void) {
init_stuff();
lcd_init();
lcd_clear();
lcd_puts("lcdterm v0.6");
lcd_goto(0x40);
lcd_puts("2000 Bob Blick");
delayMs(250);
delayMs(250);
lcd_clear();
while(1) {
if (receivebufferfull)
rs232lcd(rs232_getch());
if(kbtaskflag)
kbtaskflag = 0;
kbrs232(scankb());
} // End of "while(1)"
} // End of "main()"
// THE FUNCTIONS
void init_stuff(void) {
PORTB = 0 | (SUPER_MX_OUT_INIT & 1); //RB0 set to lo bit of super_mx_out
TRISA = 0b00011111; // PORTA inputs.
TRISB = 0b00000000; // PORTB outputs
receivestate = RS_HAVE_NOTHING;
receivebufferfull = 0;
skipoversamples = 1; // check each interrupt for start bit
kbtaskcount = KB_TASK_PERIOD;
kbtaskflag = 0;
kbdelaycount = KB_DELAY_LOAD;
kbrepeatcount = KB_REPEAT_RATE;
kboldkey = KB_NO_KEY;
command_next = 0;
super_mx_out = SUPER_MX_OUT_INIT;
#ifdef LCD_FORMAT
cursorpos = 0;
#endif
/* Set up the timer. */
T0CS = 0; // Set timer mode for Timer0
TMR0 = (2-TIMER_VALUE); // +2 as timer stops for 2 cycles
// when writing to TMR0
T0IE = 1; // Enable the Timer0 interrupt
GIE = 1; // Enable interrupts
void rs232_putch(byte c) {
while(send_bitno)
continue;
tx_next_bit = 0;
sendbuffer = c;
send_bitno = TRANSMIT_NUM_BITS*RX_OVERSAMPLE;
byte rs232_getch(void) {
while(!receivebufferfull)
continue;
return receivebuffer;
/* Interrupt service routine
* Transmits and receives characters which have been
* "rs232_putch"ed and "rs232_getch"ed.
* This ISR runs BRATE * RX_OVERSAMPLE times per second.
interrupt void isr(void) {
TMR0 += -TIMER_VALUE + 2; // +2 as timer stops for 2 cycles when writing to TMR0
T0IF = 0;
/*** RECEIVE ***/
if( --skipoversamples == 0) {
skipoversamples++; // check next time
switch(receivestate) {
case RS_HAVE_NOTHING:
/* Check for start bit of a received char. */
if(RxData){
skipoversamples = RX_BITCENTER;
receivestate++;
break;
case RS_WAIT_HALF_A_BIT:
if(RxData) { // valid start bit
skipoversamples = RX_OVERSAMPLE;
receivestate++;
} else
break;
// case RS_HAVE_STARTBIT: and subsequent values
default:
rxshift = (rxshift >> 1) | ((!RxData) << 7);
receivestate++;
break;
case RS_WAIT_FOR_STOP:
receivebuffer = rxshift;
receivebufferfull = 1;
break;
/*** TRANSMIT ***/
/* This will be called every RX_OVERSAMPLEth time
* (because the RECEIVE needs to over-sample the incoming data). */
if(send_bitno) {
if((send_bitno & (RX_OVERSAMPLE-1)) == 0) {
TxData = !tx_next_bit; // Send next bit.
tx_next_bit = sendbuffer & 1;
sendbuffer = (sendbuffer >> 1) | 0x80;
send_bitno--; //count down until out of bits to send
/*** COUNTERS ETC ***/
if(delaycount)
delaycount--;
if(!(--kbtaskcount))
kbtaskflag = 1;
// END of interrrupt service routine
// LCD ROUTINES FOLLOW
// Clear and home the LCD
void lcd_clear(void) {
lcd_putcmd(0x01);
delayMs(3);
// write a string of chars to the LCD
void lcd_puts(const byte * s) {
while(*s)
lcd_putch(*s++);
// write one character to the LCD
void lcd_putch(byte c) {
LCD_RS = 1; // write characters
PORTB &= 0x0F;
PORTB |= c & 0xF0;
LCD_STROBE;
PORTB &= 0x0F;
PORTB |= c << 4;
LCD_STROBE;
//only need these next two lines if using super multiplexed outputs
PORTB &= 0b00000111; //drop the 5 upper pins
PORTB |= super_mx_out & 0b11111000; //now raise them according to super_mx_out
delaycount = T_120_US;
while(delaycount);
// Go to the specified position
void lcd_goto(byte pos) {
lcd_putcmd(0x80+pos);
// initialise the LCD - put into 4 bit mode
void lcd_init(void) {
LCD_RS = 0; // write control bytes
delayMs(50); // power on delay. LCD spec is 15 but some don't make it
PORTB &= 0x0F;
PORTB |= 0x30; //repeat this initialization 3 times
LCD_STROBE;
delayMs(5);
LCD_STROBE;
while(delaycount);
LCD_STROBE;
delayMs(5);
PORTB &= 0x0F;
PORTB |= 0x20; //set 4 bit mode
LCD_STROBE;
while(delaycount);
#ifdef TWOLINE_5X7
lcd_putcmd(0x28); // 4 bit mode, 1/16 duty, 5x7 font
#endif
#ifdef ONELINE_5X7
lcd_putcmd(0x20); // 4 bit mode, 1/8 duty cycle, 5x7 font
#endif
#ifdef ONELINE_5X10
lcd_putcmd(0x24); // 4 bit mode, 1/8 duty cycle, 5x10 font
#endif
lcd_putcmd(0x08); // display off
#ifdef CURSOR_ON_NOBLINK
lcd_putcmd(0x0E); // display on with plain cursor
#endif
#ifdef CURSOR_OFF_BLINK
lcd_putcmd(0x0D); // display on with blink character
#endif
#ifdef CURSOR_OFF_NOBLINK
lcd_putcmd(0x0C); // display on, no cursor
#endif
#ifdef CURSOR_ON_BLINK
lcd_putcmd(0x0F); // display on, cursor, blink character
#endif
lcd_putcmd(0x06); // entry mode = increment cursor, freeze display
// Write to a command register of LCD
void lcd_putcmd(byte c) {
LCD_RS = 0;
PORTB &= 0x0F;
PORTB |= c & 0xF0;
LCD_STROBE;
PORTB &= 0x0F;
PORTB |= c << 4;
LCD_STROBE;
while(delaycount);
// End of LCD functions
// Delay a number of milliseconds
void delayMs(byte t) {
do
delaycount = T_1000_US;
while(delaycount);
} while(--t);
//write a string of characters out the serial port
void rs232_puts(const byte * s) {
while(*s)
rs232_putch(*s++);
// Scan the keyboard, return first key found or KB_NO_KEY if none found
// if you change the number of rows or columns, change KB_NO_KEY to reflect it
byte scankb(void) {
byte delay;
byte key = 0; // first key returns 0, no key returns KB_NO_KEY
byte column = 0b00001000; //RB3 is starting column.
//if you reduce columncount it will sequence through fewer columns - ending earlier,
//or starting later if you choose a different start column
byte columncount = 6; // one more than the number of columns
while(--columncount)
PORTB |= column; //energize column but leave low 3 pins untouched
for (delay = 10; --delay;); //this delay rejects key capacitance
//test each row in sequence
if(RA0)
break;
key++;
//if you don't use all rows just remove
if(RA1)
break;
key++;
//or comment out ones you don't need
if(RA2)
break;
key++;
if(RA3)
break;
key++;
column <<= 1; //shift to left, energize next column
// Only need these next 4 lines if using super multiplexed inputs
TRISB = 0b11111000; //prepare to read by making upper 5 bits input
for (delay = 10; --delay;); //now a short delay before reading the pins
super_mx_in = PORTB;
TRISB = 0; //back to all output
// Only need these next 2 lines if using super multiplexed outputs
PORTB &= 0b00000111; //drop all keyboard columns
PORTB |= super_mx_out & 0b11111000; //raise the ones that need raisin'
return key;
// Converts raw key codes to rs232 activity. Very versatile, but uses a lot of ROM
// Cutting out only one of the modes saves 50 words.
void kbrs232(byte key) {
byte kb_event_state;
enum kb_event_state {
KBES_NONE, //idle keyboard
KBES_KEYDOWN, //key down occurred
KBES_KEYUP, //key up occurred
KBES_KEYHOLD, //still holding, repeat counter not run out
KBES_KEYREPEAT //repeatcount has run out
// Figure out what type of event happened
if(key == KB_NO_KEY) //no keys are down
if(kboldkey == KB_NO_KEY)
kb_event_state = KBES_NONE;
else
kb_event_state = KBES_KEYUP;
else //yes there is a key down somewhere
if(kboldkey == KB_NO_KEY) {
kb_event_state = KBES_KEYDOWN;
kboldkey = key;
else
if(kbdelaycount) //still counting
kb_event_state = KBES_KEYHOLD;
else //count ran out
kb_event_state = KBES_KEYREPEAT;
// Each key can have its own programming mode, here are 4 samples
switch(Kb_tbl_mode[kboldkey]) {
case (0): //keydown=primary repeat=primary
switch(kb_event_state) {
case(KBES_NONE):
kbrepeatcount = 1;
break;
case(KBES_KEYDOWN):
rs232_putch(Kb_tbl_pri[kboldkey]);
break;
case(KBES_KEYUP):
kbrepeatcount = 1;
break;
case(KBES_KEYHOLD):
if(kbdelaycount)
kbdelaycount--; //never go below zero
break;
case(KBES_KEYREPEAT):
if(!(--kbrepeatcount)) {
break;
} break;
case(1): //keydown=primary keyup=secondary
case(KBES_NONE):
kbrepeatcount = 1;
break;
case(KBES_KEYDOWN):
break;
case(KBES_KEYUP):
rs232_putch(Kb_tbl_sec[kboldkey]);
kbrepeatcount = 1;
break;
case(KBES_KEYHOLD):
break;
break;
} break;
case(2): //keyup=primary keyhold=secondary
case(KBES_NONE):
kbrepeatcount = 1;
break;
case(KBES_KEYDOWN):
break;
case(KBES_KEYUP):
if(kbdelaycount) {
kbrepeatcount = 1;
break;
case(KBES_KEYHOLD):
if(kbdelaycount)
break;
case(KBES_KEYREPEAT): // use kbrepeatcount to
if(kbrepeatcount) { // insure this only happens once
kbrepeatcount = 0;
break;
} break;
case(3): //keyup=primary keyrepeat=secondary
case(KBES_NONE):
kbrepeatcount = 1;
break;
case(KBES_KEYDOWN):
kbrepeatcount = KB_DELAY_LOAD; // first repeat has long delay
break;
case(KBES_KEYUP):
if(kbdelaycount) {
kbrepeatcount = 1;
break;
case(KBES_KEYHOLD):
if(kbdelaycount)
break;
if(kbrepeatcount==KB_DELAY_LOAD) { // immediately send
if(!(--kbrepeatcount)) { //then long wait until repeats
break;
} break;
default:
break;
// Sends rs232 received data to LCD or translates if needed
// Certain commands require a second byte for data, uses command_next as flag.
void rs232lcd(byte rec) {
if (command_next) { // extended commands, this is the data byte
command_next = 0;
switch (lcdcommand) {
case(0x01): // control-A, cursor move to
lcd_goto(rec);
#ifdef LCD_FORMAT
cursorpos = rec;
#endif
return;
case(0x10): // control-P, to multiplexed output
super_mx_out = rec;
if(rec & 1) //lo bit set
RB0 = 1; //make RB0 follow
else
RB0 = 0;
return;
case(0x12): // control-R, direct LCD command
lcd_putcmd(rec);
return;
case(0x14): // control-T, direct LCD data
lcd_putch(rec);
return;
default:
break;
if(rec < 0x20) {
switch(rec) {
case (0x02): //control-B, cursor left
lcd_putcmd(0x10); //move cursor left
#ifdef LCD_FORMAT
dec_cursor();
#endif
break;
case (0x03): //control-C
lcd_clear(); //clear the LCD
#ifdef LCD_FORMAT
cursorpos = 0;
#endif
break;
case (0x06): //control-F, cursor right
lcd_putcmd(0x14); //move cursor right
#ifdef LCD_FORMAT
inc_cursor;
#endif
break;
case (0x08): //control-H, backspace
lcd_putcmd(0x10); //left
#ifdef LCD_FORMAT
dec_cursor();
#endif
lcd_putch(0x20); //space
#ifdef LCD_FORMAT
inc_cursor();
#endif
#ifdef LCD_FORMAT
dec_cursor();
#endif
break;
case (0x0A): //control-J, line feed
case (0x0D): //control-M, carriage return
lcd_goto(0); //home position
#ifdef LCD_FORMAT
cursorpos = 0;
#endif
break;
case (0x0E): // control-N, send multiplexed inputs out rs232
rs232_putch(super_mx_in);
break;
default: //codes not listed can use next byte as data
command_next = 1;
lcdcommand = rec;
break;
else {
if((rec >= 0x80) && (rec < 0xA0)) { //remapping from empty area
rec &= 0x07; //to custom character area
#ifdef DESCENDERS
if(rec==0x67 || rec==0x6A || rec==0x70 || rec==0x71 || rec==0x79)
rec += 0x80;
#endif
lcd_putch(rec);
#ifdef LCD_FORMAT
inc_cursor();
#endif
#if defined LCD_4X20
void inc_cursor(void) {
cursorpos++;
switch(cursorpos) {
case (END_LINE_1 + 1):
cursorpos = BEGIN_LINE_2;
lcd_goto(cursorpos);
break;
case (END_LINE_2 + 1):
cursorpos = BEGIN_LINE_3;
break;
case (END_LINE_3 + 1):
cursorpos = BEGIN_LINE_4;
break;
case (END_LINE_4 + 1):
cursorpos = BEGIN_LINE_1;
break;
#elif defined LCD_2X8 || defined LCD_2X16 || defined LCD_2X20
cursorpos++;
switch(cursorpos) {
break;
break;
#elif defined LCD_1X16
cursorpos++;
switch(cursorpos) {
break;
#endif
void dec_cursor(void) {
cursorpos--;
switch(cursorpos) {
case (LINE_1_MINUS_1):
cursorpos = END_LINE_4;
break;
case (LINE_2_MINUS_1):
cursorpos = END_LINE_1;
break;
case (LINE_3_MINUS_1):
cursorpos = END_LINE_2;
break;
case LINE_4_MINUS_1:
cursorpos = END_LINE_3;
break;
cursorpos--;
switch(cursorpos) {
break;
break;
cursorpos--;
switch(cursorpos) {
break;
#endif
//END ALL |
