Dabar yra 2026 06 02, 21:23. Visos datos yra GMT + 2 valandos.
 Forumas » Garso aparatūra » phono korekcinio derejimas su power ampu
Puslapis 13
Pereiti prie 1, 2, 3  Toliau
PranešimasParašytas: 2014 01 06, 00:07 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
sveiki
Power ampas+korektorius-kuris variantas deretu labiau?
PA-PA-Inputs: 1 pair unbalanced (RCA), 1 pair balanced (XLR). Outputs: 2 pairs binding posts. Rated power output: 30W into 8 ohms, 60W into 4 ohms (both 14.8dBW). Maximum output voltage: ±35V. Maximum output current: ±20A. Voltage gain: 26dB. Input sensitivity: 0.77V at 26dB gain. Frequency response: 1.5Hz–100kHz, –3dB at 1.5Hz, –2dB at 100kHz. Signal/noise: 150dB at full power. Distortion: 0.01% at 3W, 0.1% at 30W. Input impedance: 30k ohms balanced, 15k ohms unbalanced. Damping factor: 150 at 8 ohms. Slew rate: ±50V/µs. Power consumption: 238W.
1mas korektorius-Moving-coil/moving-magnet phono preamplifier, available with or without front-panel level control. Input sensitivity for 1V output at 1kHz: 2.2mV (MM), 220µV (MC). Maximum output level: 30V. S/N Ratio: 80dB (IHF, unweighted
2 korektorius-•Input and output connectors: RCA/phono sockets, hard gold plated
•Input sensitivity range: 1.5mV to 10mV
•Output range (for above inputs): 168mV to 1120mV
•Maximum input: 46mV rms
•Maximum output: 5.2V rms
•Gain: 41dB (112) at 1kHz
•Input impedance: 47k Ohms plus 100pF
•Output impedance (driving impedance): 1k Ohm (will drive 10k Ohms and above)
•Noise at output: -68dB Quasi-peak 20Hz to 20kHz
•Distortion: typically 0.01%
•RIAA accuracy: <0.3dB
•Frequency response: 20Hz - 100kHz ("flat", corrected to RIAA)
•Channel balance: 0.2dB
•Channel separation: 60dB
•Power supply: remotely powered using option of energy saving switched mode or PSU1 linear power supply
sirdis linktu prie pirmojo bet ka manote?
PranešimasParašytas: 2014 01 06, 01:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lampavykas
Apie antrą pateikta reikalinga informacija:
Apie pirmo išėjimo galimybes nieko nepasakyta.
Tą ir manom.
 Re: phono korekcinio derejimas su power ampu
PranešimasParašytas: 2014 01 06, 13:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25 rašo:
sveiki Power ampas+korektorius-kuris variantas deretu labiau?
Čia maždaug yra taip - vieno aparato aprašyme pateiktas svoris ir plotis, o kito aprašyme spalva ir aukštis. Kuris iš jų yra geresnis ?
PranešimasParašytas: 2014 01 06, 14:11 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
Laughing tai gal man sugalvoti paciam,kaip manai is kur jos Question
plotis ir aukstis Laughing
kazkam sunkus pirmadienis-klausimas ne kuris geresnis o kuris sugyventu su ampu-nebutu problemu,jie abu geri,tik pirmas labiau Smile
pirmojo matavimai http://www.stereophile.com/content/ear-834p-phono-preamplifier-measurements
PranešimasParašytas: 2014 01 06, 14:25 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lampavykas
Iš matavimų:
The output impedance measured 524 ohms in the left channel, 538 ohms in the right.
Teoriškai patemps 30 kom stiprintuvą net dvigubai geriau negu tas antras. Tik visi matavimai pirmam kažkodėl daryti 100 kom apkrovai. Įdomu, kodėl? Rolling Eyes
PranešimasParašytas: 2014 01 06, 14:37 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
o jei 15 kilooomu?
radau vieno turetojo patarima-Also be aware that this phono stage is remarkably sensitive to the loading of the input on the preamp, especially with a 12AX7 type in the cathode follower position. Pay very close attention to cable capacitance etc and try to make sure it sees 100 KOhm or more at the preamp, otherwise it sounds rather sat-on and non-special IME.
kas cia turima omenyje?
be 100kohm niekaip? Crying or Very sad
PranešimasParašytas: 2014 01 06, 16:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vinor
Nu dar nemačiau kad jungtų korekcinį stiprintuvą tiesiai į galinį stiprintuvą, statyk buferį ir nebus problemų.
O buferio stiprinimas pasirenkamas koks norimas. nuo 1 iki ........
PranešimasParašytas: 2014 01 06, 17:45 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lampavykas
Jeigu vienas gamintojas sako, kad 1k "draivins" 10k, tai kodėl kito gamintojo 0.5k turi "nedraivint" 15k? Čia gi pirmos klasės lygio aritmetika.
Neaišku iš kur tas 15k atsiranda - nesimetrinį šaltinį jungsim į simetrinį stiprintuvo įėjimą, kai stiprintuvas turi ir nesimetrinį? Koks "tolkas" iš tokio jungimo? Ypač, kai tas simetrinis visai nestandartinis - varža turėtų būti 600 Omų, o ne kažkokie 2 po 15k. Nors dabar kas kaip nori tas taip daro. Smile
vinor rašo:
Vinor, apie ką sapnuojam? Nuo kada "buferis" stiprina? Ir kam stiprinti 30V signalą, kai stipro jautrumas 0.77V? Rolling Eyes
PranešimasParašytas: 2014 01 06, 18:16 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
jis turi garso reguliatoriu-dirbs kaip preampas,jungciau i nebalansinius isvadus,bet kolega apturejo panasia problema praktiskai ir jo lempinis korektorius nedirbo su stiprintuvo 20kohm...
pasibandyti galimybiu neturiu-cia buferis padetu?
PranešimasParašytas: 2014 01 06, 20:32 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lampavykas
Teoriškai padėtų, praktiškai gali ir sugadint - dar viena dėžė su savo šniūrais.
PranešimasParašytas: 2014 01 06, 21:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
lempa su tranzu problematiska...
PranešimasParašytas: 2014 01 06, 21:56 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lampavykas
Taip. Nebent lempos išėjime transformatorius. Tada ir 600 omų apkrova nebaisi:
http://oldradio.tesla.hu/rajzok/erosito/eag%20ak706%20a.jpg
PranešimasParašytas: 2014 01 07, 16:02 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
juokingiausia jog ir stiprintuvo ir korektoriaus gamintojai atrase lakoniskus atsakymus jog problemu neiskils Smile Sad
PranešimasParašytas: 2014 01 07, 17:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lampavykas
Praktiškai yra toks prietaras, kad jeigu apkrovos varža bent dešimt kartų didesnė už išėjimo varžą, viskas bus gerai. Taip pat praktiškai, kuo šaltinio išėjimo varža yra mažesnė, tuo mažiau "girdisi" kabeliai. Smile Kitaip sakant, tuo mažesnė tų kabelių talpumo įtaka. Kitiems tokios smulkmenos paprasčiausiai "nesigirdi", tai gal galima ir nesukti dėl to galvos?
PranešimasParašytas: 2014 01 07, 17:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kvarkas25
zmones kalba jog dusta tos lempos nors tu ka-garsas bus bet ar pilnam potenciale,turbut sterophile ir neveltui pasimatavo prie 100kohm Idea
