Dabar yra 2026 05 11, 22:17. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » Atmega8 + ds18b20
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 17:23 Pranešti apie taisyklių pažeidimą Atsakyti su citata
maklas
Sveiki, esu naujokas elektronikoje... Susidūriau su bėda jungdamas temperatūros sensorių prie mikrovaldiklio.
Simuliacijos programoje tikrinant schemą gaunu labai daug klaidų:
http://www.part.lt/img/d28f3e693ec8092ac0398ce60a65c6f4306.png
Galbūt kas padėtų? Smile
main.c
Kodas:
#include <avr/io.h>
#include <stdio.h>
#include "lcd.h"
#include "tsensorius.h"
char temp[4];
int main(void)
   int i=0;
   //DDRB |= 1;
   InitLCD(LS_BLINK|LS_ULINE);
   LCDClear();
   LCDWriteStringXY(0,0,"Lauko");
   LCDWriteStringXY(8,0,"Variklio");
   //LCDWriteStringXY(1,1,"26 C");
   //LCDWriteStringXY(11,1,"78 C");
   while(1)
         i = (i+1)%10;
         char x[4]={0};
         therm_read_temperature(x);
         sprintf(temp,"%s",x);
         LCDWriteStringXY(1,1,temp);
tsensorius.h
Kodas:
#include <avr/io.h>
#include <stdio.h>
#ifndef F_CPU
   #define F_CPU 3000000UL       //Your clock speed in Hz (3Mhz here)
#endif
#define LOOP_CYCLES 8             //Number of cycles that the loop takes
#define us(num) (num/(LOOP_CYCLES*(1/(F_CPU/1000000.0))))
#define THERM_PORT PORTB
#define THERM_DDR DDRB
#define THERM_PIN PINB
#define THERM_DQ PB5
/* Utils */
#define THERM_INPUT_MODE() THERM_DDR&=~(1<<THERM_DQ)
#define THERM_OUTPUT_MODE() THERM_DDR|=(1<<THERM_DQ)
#define THERM_LOW() THERM_PORT&=~(1<<THERM_DQ)
#define THERM_HIGH() THERM_PORT|=(1<<THERM_DQ)
/* list of these commands translated into C defines:*/
#define THERM_CMD_CONVERTTEMP 0x44
#define THERM_CMD_RSCRATCHPAD 0xbe
#define THERM_CMD_WSCRATCHPAD 0x4e
#define THERM_CMD_CPYSCRATCHPAD 0x48
#define THERM_CMD_RECEEPROM 0xb8
#define THERM_CMD_RPWRSUPPLY 0xb4
#define THERM_CMD_SEARCHROM 0xf0
#define THERM_CMD_READROM 0x33
#define THERM_CMD_MATCHROM 0x55
#define THERM_CMD_SKIPROM 0xcc
#define THERM_CMD_ALARMSEARCH 0xec
/* constants */
#define THERM_DECIMAL_STEPS_12BIT 625 //.0625
void therm_delay(uint16_t delay);
uint8_t therm_reset();
void therm_write_bit(uint8_t bit);
uint8_t therm_read_bit(void);
uint8_t therm_read_byte(void);
void therm_write_byte(uint8_t byte);
void therm_read_temperature(char *buffer);
void therm_read_temperature2(int8_t *digi, uint16_t *deci);
tsensorius.c
Kodas:
   while(delay--) asm volatile("nop");
   uint8_t i;
   //Pull line low and wait for 480uS
   THERM_LOW();
   THERM_OUTPUT_MODE();
   therm_delay(us(480));
   //Release line and wait for 60uS
   THERM_INPUT_MODE();
   therm_delay(us(60));
   //Store line value and wait until the completion of 480uS period
   i=(THERM_PIN & (1<<THERM_DQ));
   therm_delay(us(420));
   //Return the value read from the presence pulse (0=OK, 1=WRONG)
   return i;
   //Pull line low for 1uS
   THERM_LOW();
   therm_delay(us(1));
   //If we want to write 1, release the line (if not will keep low)
   if(bit) THERM_INPUT_MODE();
   //Wait for 60uS and release the line
   THERM_INPUT_MODE();
   uint8_t bit=0;
   THERM_LOW();
   therm_delay(us(1));
   //Release line and wait for 14uS
   THERM_INPUT_MODE();
   therm_delay(us(14));
   //Read line value
   if(THERM_PIN&(1<<THERM_DQ)) bit=1;
   //Wait for 45uS to end and return read value
   therm_delay(us(45));
   return bit;
   uint8_t i=8, n=0;
   while(i--)
      //Shift one position right and store read value
      n>>=1;
      n|=(therm_read_bit()<<7);
   return n;
   uint8_t i=8;
   while(i--)
      //Write actual bit and shift one position right to make the next bit ready
      therm_write_bit(byte&1);
      byte>>=1;
   // Buffer length must be at least 12bytes long! ["+XXX.XXXX C"]
   uint8_t temperature[2];
   int8_t digit;
   uint16_t decimal;
   //Reset, skip ROM and start temperature conversion
   therm_reset();
   therm_write_byte(THERM_CMD_SKIPROM);
   therm_write_byte(THERM_CMD_CONVERTTEMP);
   //Wait until conversion is complete
   while(!therm_read_bit());
   //Reset, skip ROM and send command to read Scratchpad
   therm_reset();
   therm_write_byte(THERM_CMD_RSCRATCHPAD);
   //Read Scratchpad (only 2 first bytes)
   temperature[0]=therm_read_byte();
   temperature[1]=therm_read_byte();
   therm_reset();
   //Store temperature integer digits and decimal digits
   digit=temperature[0]>>4;
   digit|=(temperature[1]&0x7)<<4;
   //Store decimal digits
   decimal=temperature[0]&0xf;
   decimal*=THERM_DECIMAL_STEPS_12BIT;
   //Format temperature into a string [+XXX.XXXX C]
   sprintf(buffer, "%+d.%04u C", digit, decimal);
   int8_t digit;
   uint16_t decimal;
   therm_reset();
   therm_reset();
   therm_reset();
   //results
   *digi = digit;
   *deci = decimal;
Paskutinį kartą redagavo maklas, 2013 12 28, 18:58. Redaguota 1 kartą
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 18:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
pcwortex
tingiu visa ziureti koda, bet i main.c pradzioje irasyk tokias eilutes. Nes main.c faile nera nurodyta kokias bibliotekas naudosi
Kodas:
#include <avr/io.h>
#include <stdio.h>
Diplomas tik etikete ant konservų dėžutes. O kas slepiasi dėžutėje neaišku.
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 18:59 Pranešti apie taisyklių pažeidimą Atsakyti su citata
maklas
pcwortex rašo:
Kodas:
#include <avr/io.h>
#include <stdio.h>
Pridėjau.
Gal kas galėtų peržiūrėti visą kodą?
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 19:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
pcwortex
Nepaziurejau, tavo paveiksliuko. Tau kodas veikia. Maniau, kad neveikia. O kas ziures visa koda, tai man rodos cia nerasi tokiu zmoniu. turi aiskintis pats ir kas neaisku klausti. Bet kiek suprantu, tu susiradai koda, padarei copy paste ir viskas. Pirmiausia pradek nuo lempuciu junginejimu, o ne sok iskart ant protokolu.
maklas rašo:
pcwortex rašo:
Kodas:
#include <avr/io.h>
#include <stdio.h>
Pridėjau.
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 21:47 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
pradekim nuo to, kad void therm_read_temperature(char *buffer); gali reiketi didesnio buferio nei 4 baitai, t.y. reikia iki 12 baitu // Buffer length must be at least 12bytes long! ["+XXX.XXXX C"]
gali pasinaudoti kita funkcija, kuri grazina sveikus skaicius void therm_read_temperature2(int8_t *digi, uint16_t *deci) sveikaja dali i uint8_t, bei po kablelio i uint16_t kintamuosius.
perduodant kintamuju adresus gali reiketi nurodyti &kintamasis, nes kintamieji proceduroje aprasyti adresu *kintamasis.
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 22:52 Pranešti apie taisyklių pažeidimą Atsakyti su citata
maklas
Štai kodas:
Kodas:
#include <avr/io.h>
#include <stdio.h>
#include "lcd.h"
int main(void)
   LCDClear();
   while(1)
         int8_t x;
         uint16_t y;
         char temp[10];
         therm_read_temperature2(&x,&y);
         sprintf(temp, "%i.%i", x, y);
Tačiau visada išvedama temperatūra: 127.9375
Kur padariau klaidą?
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 28, 23:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
tavo biblioteka nenaudoja INPUT_PULLUP mode, todel reikia DQ (PB5) per 4,7kom varza prijungti prie VCC
beje, jei laidas poilgis, tai PULLUP naudoti nepatartina.
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 29, 00:13 Pranešti apie taisyklių pažeidimą Atsakyti su citata
maklas
AlgisL rašo:
Ačiū tau, viskas sėkmingai veikia.
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 29, 02:42 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
keliems davikliams lygiagreciai http://siwawi.bauing.uni-kl.de/avr_projects/tempsensor/
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 31, 11:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
maklas
Vienas daviklis veikia puikiai, tačiau kitas nuolat į LCD išveda -63C. Kur klaida?
Kodas:
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <util/delay.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/eeprom.h>
#include "lcd.h"
#include "1wire.h"
|* Function prototypes
int16_t ds18b20ReadTemperature(uint8_t bus, uint8_t * id);
|* Defines for the temperature conversion
#define DS18B20_FAMILY_ID                0x28
#define DS18B20_SKIP_ROM               0xcc
#define DS18B20_START_CONVERSION         0x44
#define DS18B20_READ_SCRATCHPAD          0xbe
#define DS18B20_WRITE_SCRATCHPAD       0x4e
#define DS18B20_COPY_SCRATCHPAD          0x48
#define DS18B20_ERROR                    -1000
|* Make the 1-wire "bus" on pin-7 of port ONEWIRE_PORT (see 1wire.h)
#define BUS                      ONEWIRE_PIN_0
#define BUS2                      ONEWIRE_PIN_1
#define MAX_DEVICES                1
|* Set up stdio
uint8_t crap[7];
|* Initialise the firmware - program entry point
int main (void)
   signed int temp = 0;
   signed int temp2 = 0;
   |* Set up the uart
   LCDClear();
   LCDWriteStringXY(0,0,"Kraunama...");
   |* Declare the devices and initialise
   static oneWireDevice devices[MAX_DEVICES];
   static oneWireDevice devices2[MAX_DEVICES];
   oneWireDevice *ds18b20;
   oneWireDevice *ds18b202;
   oneWireInit(BUS);
   oneWireInit(BUS2);
   |* Search for and populate the devices until all CRC's are read correctly
   LCDClear();
   LCDWriteStringXY(0,0,"Ieskoma...");
   while (oneWireSearchBuses(devices, MAX_DEVICES, BUS) != ONEWIRE_SEARCH_COMPLETE && oneWireSearchBuses(devices2, MAX_DEVICES, BUS2) != ONEWIRE_SEARCH_COMPLETE);
   |* After device enumeration, find the temperature sensor
   LCDClear();
   LCDWriteStringXY(0,0,"Ieskomi davikliai...");
   ds18b20 = oneWireFindFamily(DS18B20_FAMILY_ID, devices, MAX_DEVICES);
   ds18b202 = oneWireFindFamily(DS18B20_FAMILY_ID, devices2, MAX_DEVICES);
   |* Just print the temperature constantly
   LCDClear();
   while (1)
      temp    = ds18b20ReadTemperature(ds18b20->bus, ds18b20->id);
      temp = (temp >> 4);
      temp2    = ds18b20ReadTemperature(ds18b202->bus, ds18b202->id);
      temp2 = (temp2 >> 4);
      char a[6], b[6];
      sprintf(a, "%i.0", temp);
      LCDWriteStringXY(0,1,a);
      sprintf(b, "%i.0", temp2);
      LCDWriteStringXY(9,1,b);
|* Read the temperature from an identified sensor
    int16_t temperature;
    // Reset, presence.
    if (!oneWireDetectPresence(bus))
        return DS18B20_ERROR;
    // Match the id found earlier.
    oneWireMatchRom(id, bus);
   //oneWireSendByte(DS18B20_SKIP_ROM, bus);
    // Send start conversion command.
    oneWireSendByte(DS18B20_START_CONVERSION, bus);
   // Wait until conversion is finished.
    // Bus line is held low until conversion is finished.
#ifdef ONEWIRE_USE_PARASITIC_POWER
   ONEWIRE_RELEASE_BUS(bus);
   _delay_ms(850);
#else
    while (!oneWireReadBit(bus))
#endif
    // Reset, presence.
    if(!oneWireDetectPresence(bus))
    // Match id again.
    // Send READ SCRATCHPAD command.
    oneWireSendByte(DS18B20_READ_SCRATCHPAD, bus);
    // Read only two first bytes (temperature low, temperature high)
    // and place them in the 16 bit temperature variable.
    temperature = oneWireReceiveByte(bus);
    temperature |= (oneWireReceiveByte(bus) << 8);
   uint8_t i;
   for(i=0; i<7; i++)
      crap[i] = oneWireReceiveByte(bus);
    return temperature;
 Atmega8 + ds18b20
PranešimasParašytas: 2013 12 31, 16:36 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
Kodas:
cia pasakai, kad kai nors viena davikli rado, kito ieskoti nebereikia Very Happy
vietoje && naudok || arba davikliu ieskok paeiliui, paradzioje BUS, paskui BUS2
DS18x20x pasizymi tuom, kad juos keleta gali jungti lygiaigreciai prie to paties BUS'o
Kodas:
#define MAX_DEVICES                2
while (oneWireSearchBuses(devices, MAX_DEVICES, BUS) != ONEWIRE_SEARCH_COMPLETE);
      temp    = ds18b20ReadTemperature(ds18b20[0]->bus, ds18b20[0]->id);
      temp = (temp >> 4);
      temp2    = ds18b20ReadTemperature(ds18b20[1]->bus, ds18b20[1]->id);
klaidu gali but del ivairiu dalyku, pvz: nepritempei prie +5V per varza, daviklis (ne)pajungtas ilgu neekranuotu laidu ir t.t.
 Atmega8 + ds18b20
PranešimasParašytas: 2014 01 08, 17:28 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Karolokas
Kokio dydžio tavo .hex failas?
