Dabar yra 2026 05 03, 23:50. Visos datos yra GMT + 2 valandos.
 Forumas » Telefonija, tinklai, ryšio elektronika » kaip is laptopo paskleisti wifi
Puslapis 22
Pereiti prie Atgal  1, 2
PranešimasParašytas: 2013 05 08, 19:53 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Jakaz
puiku kad viska,moki,nors as tuo ir netikiu....
skype-->optical611
PranešimasParašytas: 2013 05 08, 21:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Lukashenka
Click Start, type CMD, right-click the Cmd.exe link and select "Run as Administrator".
Now type the following command:
netsh wlan set hostednetwork mode=allow ssid=MyNet key=MyPassword
and press [Enter]. Replace "MyNet" with the name you'd like to use for your custom network, and "MyPassword" with a password that's a little harder to guess.
Still at the command line, type
netsh wlan start hostednetwork
and press [Enter] to fire up the virtual adapter.
Now click Control Panel > Network and Internet > Network and Sharing Centre > Change Adapter Settings, right-click your internet connection and select Properties. Click the Sharing tab, check "Allow other network users to connect...", choose your virtual Wi-Fi adaptor - and that's it.
visa tai buvo tam psl kur numeciau anksciau. zodziu, kai sita pasidarysi, atsiras naujas tinklas, BET Exclamation ijunges kompiuteri turesi paleidinet kiekviena karta - "netsh wlan start hosted network", nebent pasidarysi BAT programele su sitais zodziais, ir per scheduler paleidinesi, automatiskai kai pasileis sistema. Wink tik nepamirsk "run as administrator"
edit : paskaiciau kad pas tave XP, tai xp maziau praso to administrator negu win7
