Dabar yra 2026 05 10, 13:38. Visos datos yra GMT + 2 valandos.
Forumas » Mikrovaldikliai » STK500v2 ar MKII programatoriu rinktis?
STK500v2 ar MKII programatoriu rinktis? |
Parašytas: 2010 07 02, 14:24 |
Na nereik souru isigasti bet atkurti sita schema atrodo lengviau
O gal gali patart del tos mikroschemos signalu lygiams suderinti? Is usb 5V o xmega veikia nuo 3.3V. Ir del ko skirta HWB kontktas USBmegoj? |
_________________ Aš pažeidžiau forumo taisykles ir reklamavau paraše. ...Bet uz reklama tai susimokejau  |
Parašytas: 2010 07 02, 14:28 |
neatkursi tu shemos taip lengvai.
del suderinimo tai UISB yra 3.3v signalai tik maitinimas 5v tai statyk koki nors low dropout stabilizatoriu savo mikroshemos maitinimui.
o del HWB nezinau |
Parašytas: 2010 07 02, 14:33 |
Gera ideja det USB mikroschemai 3v maitinima  |
Parašytas: 2010 07 04, 17:57 |
Atrase autorius:
Theres no schematic for my AVRISP-MKII clone programmer, just the programmer pinout in the documentation (download the code, and run make doxygen in the AVRISP-MKII clone project folder to generate the documentation). In its simplest form you just connect the programmer AVR to the target AVR directly following the pinout in the documentation, but you are also free to add in any other features you like, such as over-current protection or voltage level translation. How you do that is entirely up to you you can use whatever parts you have available.
kaip suprasti ta ''make doxygen''? Cia su kompiliatorium kazkokiu?  |
Parašytas: 2010 07 04, 22:54 |
ta pati as tau jau sakiau
stai is to source kodo paemaiu pinouta tau nereikes beieskoti
| Kodas: |
* * \section SSec_Description Project Description: * * Firmware for an AVRStudio compatible AVRISP-MKII clone programmer. This project will enable the USB AVR series of * microcontrollers to act as a clone of the official Atmel AVRISP-MKII programmer, usable within AVRStudio. In its * most basic form, it allows for the programming of 5V AVRs from within AVRStudio with no special hardware other than * the USB AVR and the parts needed for the USB interface. If the user desires, more advanced circuits incorporating * level conversion can be made to allow for the programming of 3.3V AVR designs. * * This device spoofs Atmel's official AVRISP-MKII device PID so that it remains compatible with Atmel's AVRISP-MKII * drivers. When prompted, direct your OS to install Atmel's AVRISP-MKII drivers provided with AVRStudio. * * Note that this design currently has the following limitations: * - Minimum ISP target clock speed of 500KHz due to hardware SPI module prescaler limitations * - No reversed/shorted target connector detection and notification * - A seperate header is required for each of the ISP, PDI and TPI programming protocols that the user wishes to use * * On AVR models with an ADC converter, AVCC should be tied to 5V (e.g. VBUS) and the VTARGET_ADC_CHANNEL token should be * set to an appropriate ADC channel number in the project makefile for VTARGET detection to operate correctly. On models * without an ADC converter, VTARGET will report a fixed 5V level at all times. * * While this application can be compiled for USB AVRs with as little as 8KB of FLASH, for full functionality 16KB or more * of FLASH is required. On 8KB devices, ISP or PDI/TPI programming support can be disabled to reduce program size. * * \section Sec_ISP ISP Connections * Connections to the device for SPI programming (when enabled): * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
Programmer Pin: Target Device Pin: ISP 6 Pin Layout:
MISO PDO 1
ADCx 1 VTARGET 2
SCLK SCLK 3
MOSI PDI 4
PORTx.y 2 /RESET 5
GND GND 6
* * In addition, the AVR's XCK pin will generate a .5MHz clock when SPI programming is used, to act as an external * device clock if the fuses have been mis-set. To use the recovery clock, connect XCK to the target AVR's XTAL1 * pin, and set the ISP programming speed to 125KHz or below. * * 1 Optional, see \ref SSec_Options section - for USB AVRs with ADC modules only \n * 2 See AUX line related tokens in the \ref SSec_Options section * * \section Sec_PDI PDI Connections * Connections to the device for PDI programming1 (when enabled): * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
Programmer Pin: Target Device Pin: PDI 6 Pin Layout:
Tx/Rx 2 DATA 1
ADCx 1 VTARGET 2
N/A N/A 3
N/A N/A 4
XCLK CLOCK 5
GND GND 6
* * 1 Optional, see \ref SSec_Options section - for USB AVRs with ADC modules only \n * 2 The AVR's Tx and Rx become the DATA line when connected together via a pair of 220 ohm resistors \n * * \section Sec_TPI TPI Connections * Connections to the device for TPI programming1 (when enabled): * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
Programmer Pin: Target Device Pin: TPI 6 Pin Layout:
Tx/Rx 2 DATA 1
ADCx 1 VTARGET 2
XCLK 2 CLOCK 3
N/A N/A 4
PORTx.y 3 /RESET 5
GND GND 6 |
Parašytas: 2010 07 16, 21:57 |
Sulitavau AVRISP MKII clona, ir, veikia
Tiesa kolkas isbandziau su atmega32 per ISP, iraso per kokias 5sekundes, t.y. zymiai greiciau nei su ponyprog ir COM programatoriumi.
AvrStudio atpazysta kaip AVRISP MKII. Kai turesiu atxmega is bandysiu ir ja su PDI. |
Parašytas: 2010 07 22, 22:49 |
Gal kas zino kaip paprasciausiai padaryt "transliatoriu" 5V<>3.3V?
Esme tame kad programatorius 5V, o xmega 3.3V, buvau rades schema su keliais tranzais kazkokiam rusu puslapy, bet kai prireike neatsimenu kur..
Gal eitu su stabilitronais kaip nors? Taprasme kai is programatoriaus iseina 5V signalas, su 3.3v stabiltronu numusam itampa, o kai pati xmega siuncia savo signala 3.3v lyg ir turetu pakakt loginiam vienetui kad 5v programatorius suprastu. |
Parašytas: 2010 07 22, 23:24 |
| didshirshis rašo: |
kaip sake uzkabink varzas itr bus gerai, arba maitink programatoriaus mikroshema 3.3v ir nereikes nirko tokio daryti
gali programatoriuje ideti jungikli kur butu perjungiamas jo maitinimas 5v arba 3.3v |
Parašytas: 2010 07 22, 23:33 |
Programatorius ant 16Mhz veikia, tai ant 3.3V maitinimo nepasivelka...
Tiesiog jungt per varzas ir viskas? Kazkaip baisu sudegint
Gal dar kokia varza i zeme, tarsi itampos daliklis gautusi? |
Parašytas: 2010 07 22, 23:40 |
tikrai nesudegs dar niekam nesudege.
atmegos isvis neuzmusamos yra.
jei nori gali dar po varzos prideti 3.3v stabilitronus kad numusti atliekama itampa.
bet kazkaip man keista kad tau nuo 3.3v nedirba at 16mhz, man tai net bat 17mhz veikia be problemu ant to itampos |
Parašytas: 2010 07 22, 23:44 |
| Tai vat kad nedirba ant 3.3v - bandziau. Su 5V viskas ok. |
Parašytas: 2010 07 22, 23:47 |
| Tik nedek tu stabilitronu, bus triuksmo. Siaip atmegos turi clamp diodus tai ju tikrai neuzmusi. Del xmegu datasheete apie tai neuzsimenama, bet nenudeks ir sita... |
Parašytas: 2010 07 22, 23:56 |
| sneikaz rašo: |
| Tik nedek tu stabilitronu, bus triuksmo. Siaip atmegos turi clamp diodus tai ju tikrai neuzmusi. . |
pamirsai kad cia ne analogine shema. ir ipac ne audiofiline aparatura  |
