Dabar yra 2026 05 18, 09:01. Visos datos yra GMT + 2 valandos.
Forumas » Elektronika žaliems » LM3875 vienpolio maitinimo schema
LM3875 vienpolio maitinimo schema |
Parašytas: 2008 11 05, 23:41 |
Ogi i garsiakalbi pasiduos nuolatine (puse maitinimo itampos)
Ir isvis su sita lm'ke daryt vienpoli tai kazkokia pornografija...
Jei nori be kondiko dek kokia TDA kuriai jo nereikia. |
Parašytas: 2008 11 05, 23:54 |
Jei maitinimas vienpolis-kondensatoriaus isejime visada reikia,nepriklausomai nuo to,kokia mikre naudojama
Be jo-sudegs ir mikre,ir garsiakalbis |
Parašytas: 2008 11 06, 16:13 |
| O kaip del TDA1562Q, gal geriau ja naudot? Turiu pasidares. Mane domintu galia, o TDA1562Q garso kokybes man pilnai pakanka. |
Parašytas: 2008 11 06, 16:18 |
Ir dar, TDA1562Q ispaus tuos 70W tik tada kai bus paduota didele maitinimo itampa, ir tik trumpa laika. Jis lyg is class-B persijungs i class-H. Class-B rezimu spaus apie 20W, o tuo class-H net 70W? Ar tai tiesa? Remiausi tekstu is datasheet'o :
______
The TDA1562Q contains a mono class-H BTL output
power amplifier. At low output power, up to 18 W, the
device operates as a normal BTL amplifier. When a larger
output voltage swing is required, the internal supply
voltage is lifted by means of the external electrolytic
capacitors. Due to this momentarily higher supply voltage
the obtainable output power is 70 W.
In normal use, when the output is driven with music-like
signals, the high output power is only needed during a
small percentage of time. Under the assumption that a
music signal has a normal (Gaussian) amplitude
distribution, the reduction in dissipation is about 50% when
compared to a class-B output amplifier with the same
output power. The heatsink should be designed for use
with music signals. If the case temperature exceeds
120 °C, the device will switch back from class-H to class-B
operation. The high power supply voltage is then disabled
and the output power is limited to 20 W.
___________
OUTPUT
This output has 3 possibilities:
1. LOW, mute: acknowledge of muted amplifier
2. MID, class-B: the circuit operates as class-B
amplifier, the high power supply voltage is disabled,
caused by the case temperature Tc > 120 °C
3. HIGH, class-H: the circuit operates as class-H
amplifier, the high power supply voltage is enabled,
because the case temperature Tc < 120 °C. |
Parašytas: 2008 11 06, 22:38 |
Nejaugi nesupranti...
Reikiamas itampas mikre pasidaro pati!
Tu duodi tuos pacius 12V ir kokius min 10A fsio. |
Parašytas: 2008 11 06, 23:29 |
| RokiZ rašo: |
Tai maitymkes pakaks? Tik gaila, kad kai nuo maitymkes paleidziu, tai vos ka girdziu Uzia ir uzia. |
Parašytas: 2008 12 09, 00:46 |
Kokia dar rite-ten ant 10 omu/2-ju arba 3W varzos uzvyniota mazdaug 0,8mm storio laidu vienas sluoksnis apviju,kiek telpa
Deti reikia ne visais 100% atveju,bet neretai be jos susizadina,taip kad geriau padaryk ta rite,ten minutes darbas |
Parašytas: 2008 12 13, 22:49 |
Norejau dar paklaust, ar diodu tiltelis skirtas is AC i DC paversti? Kadangi norejau daryti dvipoli maitinima nuo akumuliatoriu, jei tai imanoma, tad galvoju, kad gal diodu tiltelio ir neprireiktu  |
